Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: VX Lift options Wiki with part numbers.
  1. #16
    2000, Kaiser, 0134
    Both threads were added to the original post
  2. #17
    Jan 2006
    Kinda on topic...
    I was wondering for those that know. Does the Isuzu coil spring retainers fit on our rigs and would we need it at all? I remember reading a thread awhile back talking about someone always having to pop his springs back into place when his rears over extended... I don't remember if it had anything to do with the VX or if it was even a Trooper or not...
  3. #18
    2001, Ebony Black, 1153
    Quote Originally Posted by Knigh7s View Post
    I don't know, I am using 4x Heavy duty Zip Ties on each spring at the bottom, seems to be working great so far.
  4. #19
    shocking
    Thanks, Randy. I was worried the H1's would be too stiff if they were made for the heavier Trooper but if they're still softer than stock, I'll give them a try.
  5. #20
    Nov 2007
    '01 Ebony Black VX, 0801; '01 Kaiser Silver VX, 1002
    By comparison....
    My 2001 OEM shocks with 60,000 miles on them are still slightly stiffer than the new Billstein H1's, but the ride comparison between the two VX's the shocks are mounted on is pretty close.
    Randy
  6. #21
    Nov 2007
    1999 Astral Silver
    Quote Originally Posted by taylorRichie View Post
    So these Subaru SVX Brake lines are what we need for our VXs?
    And thanks for contributing everyone!! I've made the edits to the main Post adding the adjustable coils.
    Planetsvx started off just being parts for the Subaru SVX
    But they do have a dedicated page for VX owners and
    custom parts too.
    Those lines are for the Vehicross specifically.
    Check out our VX accessories @
    www.planetsvx.com
    click on the Vehicross button on the left side
    of the page
  7. #22
    Nov 2003
    1999,Victory White, Ironman, #0414
    Angry 3 or 4 bolt spacers???
    For most all components to build your own lift start Here:
    http://www.independent4x.com/
    I've searched the forums best I could to get the following information. If you have an addition, please post your part, part number, and details regarding the part, and I'll add it to the original list.
    Here goes...
    --------------------- BEGIN LIST ---------------------------
    Ready to run lifts
    Calmini
    independent4X
    Rocky Road
    Components
    Energy Suspension
    Sway Bar Bushings:
    Greasable (zerk) 19mm = 355-9-5156R (G for Black instead of R)
    Greasable (zerk) 28mm = 355-9-5163R (G for Black instead of R)
    Low Profile Bumpstops: 9.913R or 9.9102R
    Tie Rod Boots: 9.13101R
    High Profile Rear Bumpstop: 9.9104R
    Coil Spacer: Independent 4X 1" Independent 4X 2"
    PROTHANE
    Sway Bar Bushings:
    19mm = 311-19-1118
    28mm = 311-19-1144
    Bump Stops:
    Low Profile = 311-19-1319 (front)
    4 1/2" High Profile = 311-19-1311 (rear)
    Stinky Fab Joint arms
    Extreme Duty Lower Links
    Bilstein Shocks
    Front - B46-1738-H2 (H1 option for more stiffness)
    Rear - B46-1739-H1
    FROM VEHIGAZ
    "I installed these on my VX (H1's in front) a couple years back, and while they are an excellent choice for the VX with a very close-to-stock ride, the rears are probably stiffer than they need to be, and a softer one might be appropriate for the VX. After all, these Bilstein models are actually the ones they recommend for the Trooper (they don't have a recommendation for the VX), and the longer Trooper probably carries more weight on the rear axle, requiring a stiffer shock to counteract the additional inertia."
    I ended up going with the Bilstein shocks, and I'm very happy*with my choice. H2s up front and H1s in the rear. I keep a heavy tool box in the rear, and from the front the rear shocks feel great. My rear seat passengers would argue that though... but I don't think anything will feel good to someone sitting directly over the rear axle.
    Old Man Emu Rear Coils - OME912
    Adjustable Coil Spacers
    Small(0"-2 1/2")P/N: 91645551
    Large(3 1/8"-5 1/4")P/N: 91645552
    Available from Speedway Motors. (clickable links above)
    Sway Bar disconnects: independent4X
    Brake Lines: independent4X
    See a trend independent 4X has just about everything.
    tie rods: Independent4X
    Extended Brake lines also available at independent4X, ebay, and basically anywhere that has 4X4 Supplies.
    ---------------- END LIST -----------------------------
    Needed:
    Poly Spacer part numbers and links
    Adjustable coil spacer part numbers and links.
    Names of recommended supply houses for any of the above components.
    Misc info:
    Torsion cranks - 3-4 turns per inch.
    Great thread on lifting
    Lifting FAQ
    Ball Joint Flip tutorial with pics
    ball Joint Spacers - independent 4X
    Drop Bracket threads:
    http://www.vehicross.info/forums/sho...eferrerid=1999
    http://www.vehicross.info/forums/sho...threadid=11230
    Which of these ball joint spacers are for the Vehicross?? 3 or 4 bolt??
    https://www.independent4x.com/mercha...products_id=30
    or
    https://id211.chi.us.securedata.net/...products_id=67
    in case I was to order a set??
    Thanks!
    Dave
    Dreamers of the day are dangerous people, for they
    dream their dreams with open eyes, and make them come true.
  8. #23
    Mar 2010
    '01 Kaiser Gray VX#0867
    Too bad they don't make on-the-fly adjustable spring spacers. The ones here tell you to get it to the right height and tack weld. What if instead of tack-welding, there was just a cotter pin to hold it in place, like the nut on a wheel bearing, or better yet, servo controlled. As you pull off the asphalt and get on a trail, twist a knob, and the VX rises to the occasion. I'm kind of surprised that after all these years, that a ride height knob isn't standard in serious 4x4 SUV's and PU's by know. Those engineers work so hard to maximize on-road stability and off-road ability at a fixed ride height. Think how much easier it would be to build a cross vehicle if ride-height was on-the-fly adjustable. Plus think of the gas savings.
    '01 Kaiser SC'ed VX #0867
  9. #24
    May 2010
    Not yet
    I've decided to get these Daystar coil spacers. Anybody try them yet?
    http://www.jackit.com/springs/coil_spacers.htm
  10. #25
    Mar 2010
    2001 Ironman 0588
    Yeah, Rickshaw checked out one of them (and even noted the real height difference was a little different than what wash shown on the box.)
    The 913 Experiment
  1. oil filter pcv valve part numbers
    By djvx in forum VX Talk...
    Last Post: 06/15/2010, 05:30 AM
  2. Replacement part numbers
    Last Post: 11/30/2006, 07:59 AM
  3. headlight gasket part numbers/replacement instructions?
    By Binger in forum VX Troubleshooting...
    Last Post: 05/12/2006, 08:54 AM
  4. part numbers
    By Bagheera in forum VX Troubleshooting...
    Last Post: 01/12/2005, 07:04 AM
  5. part numbers ??
    By BBVX in forum VX Modifications...
    Last Post: 07/28/2003, 11:33 PM
