Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: Check engine
  1. #16
    2001, Ebony Black, 1153
    Quote Originally Posted by twistedsymphony View Post
    if the CEL is on it means that the ECU is throwing a code and the vehicle wont pass inspection as a result.
    That is what I thought, but all they seem to ever check every single time is the emissions. I live in Houston and we have very strict inspections, and I used to always have troubles getting the VX inspected until I took that bulb out. I do not think they check for fault codes unless there is a light.
  2. #17
    yeah I'll definitely try cleaning it first.
    I would think that an EGR would hurt you mileage since it's routing the exhaust fumes (which is theoretically devoid of oxygen) back to your intake... wouldn't the reduction in burnable air cause a less complete burn?
    i meant to say... replacing your egr will help improve gas mileage.. when it get clogged up gas mileage suffers.. i dunno if you would gain anything by removing it all together
  3. #18
    Maybe, but also contains un-burned fuel...
  4. #19
    1997 Silver JDM 0623
    Hi ABS sensor faults are generally caused by a build up of brake dust over the sensor or the exciter rings - either a jet wash or remove the disc and clean them up works just fine - mine was coming on every so often - but since i cleaned the exciter rings and sensor face it hasn't come on once and the TOD seems to work better
    cheers
    Steve
  1. Check Engine Light
    Last Post: 11/05/2007, 08:11 AM
  2. Check Engine - Off/on/off/on what..
    By Corrosive in forum VX Troubleshooting...
    Last Post: 11/22/2006, 03:12 PM
  3. check engine
    By alobar05 in forum VX Troubleshooting...
    Last Post: 06/28/2005, 08:57 PM
  5. Check Engine
    By Eckstream in forum VX Troubleshooting...
    Last Post: 10/02/2003, 08:22 AM
