Results 1 to 12 of 12
Thread: Engine Code
    2000 IronMan #11
    Engine Code
    I have this on show up everyday. The problem is I do not know what to do to correct it. I also do notice any negative effects from it.
    P1153
    H02S Insufficient Switching Bank 2 Sensor 1
    Any insight?
    Thanks!
    2001 Proton VX #0690
    P1153
    Initial guess:
    The readings from a heated oxygen sensor are not bouncing up and down like they should. Your engine is probably running just fine, but the computer is paranoid about air quality regulations.
    First, check the wiring harnesses connecting to the oxygen sensors, then check the plugs going into the computer (behind the panel under the CD player).
    I don't know where the O2 sensors are, though. Look for things bolted into your exhaust system pipes with wires coming off of them.
    2000 IronMan #11
    This code is back!!!!
    Any advice would be greatly appreicated.
    --- What do I look for or replace?
    '99
    From the repair manual-
    P1153 Diagnostic Flow Chart
    Mark
    2000 IronMan #11
    Well this one is back.....It was gone for quite a while now this and I have....
    P0154
    H02S Circuit Insufficient Activity Bank 2 Sensor 1
    ...Any idea how to cure this one?
    I am now down about 4.5mpg these last 4 tank fills....
    Apr 2003
    1999,white,ironman,1497
    Noticed the wheels and tires combo on your VX..can you give me the brands and sizes of the wheels and tires..
    I am looking for a new set....do these need a lift kit??
    Quote Originally Posted by majork View Post
    Click here... http://www.vehicross.info/forums/sho...1&postcount=19
    Scroll down about 8 pics, enjoy...
    JHarris1385
    Rims are 16x8 Pro-Comp 8089's with 4.5 backspacing
    Tires are 265-75-16 A/T tires (Diameter 31.6 in)
    2000 IronMan #11
    I already messaged him the info and prices. Could we stay on topic?
    I suppose we could try something new mr haris...
    I have no response to that.
    Apr 2003
    Most Appreciated
    The wheels caught my eye while I was researching DTC P0502....please continue
    2000 IronMan #11
    Anybody? I am not familiar with the code...the second code that is.
    Thanks in advance.
  1. CHECK ENGINE light - code P0440
    By Yefim in forum VX Troubleshooting...
    Last Post: 03/07/2013, 05:54 PM
  2. Check engine light, no code thrown
    By Marlin in forum VX Troubleshooting...
    Last Post: 01/03/2011, 08:20 AM
  3. Engine code P1441 - any thoughts?
    By dkmiller68 in forum VX Troubleshooting...
    Last Post: 04/14/2009, 11:31 AM
  4. Engine Code P0171-any suggestions?
    By drdavidr4u in forum VX Troubleshooting...
    Last Post: 03/02/2005, 06:31 AM
  5. Replies: 1
