Results 1 to 8 of 8
Thread: Aftermarket MAS
    2001 Proton VX 0790
    Aftermarket MAS
    http://cgi.ebay.com/ebaymotors/ws/eB...tem=2421284032
    Bigger mass air sensor, supposedly 50 states legal too. anyone tried this on our truck yet?
    John C.
    2000 Dragon Green VX 0485
    Pop the metal screen out of the VX MAFS & you will have the same thing for free? Mines been out for <a year.
    An Axiom owner with the SC sent me this:
    Granatelli Motorsports has a cold air calibrated MAF sensor for the Axiom/Vehicross. The part number cross referenced to the '94-96 Impalla SS which you can get at Summit Racing for $329. The part number is 350114-C.
    http://www.granatellimotorsports.com/pdf/retail.pdf
    Is it a real improvement?
    Apr 2003
    2001 Grey VX 0867
    MAS = O2 Sensor?
    Sorry if this question is somewhat remedial for some owners, but what exactly is a Mass Airflow Sensor. Is it the same thing as the O2 sensor? If so, must we purchase two of them when we upgrade? Second, a mechanic friend of mine said that gas mileage has a lot to do with airflow to the engine and that's why the airflow sensor would improve gas mileage. If this is true, would adding a hood scoop also have the same effect? I have both modifications in mind and could use some quality input. Lastly, regarding anti-sway bars: Calmini or Hellwig? Tight corners are not the VX's forte, and any help would be great!! Thanks ahead for anyone's know-how!
    '99 Astral #1977
    Looks like the same company from the post above from E-Bay?
    RichD
    Oct 2002
    Re: MAS = O2 Sensor?
    In short, the MAS is the sensor at the intake (located near the airbox along the intake tube). This sensor measures intake air and sends the information on to the brain of the engine (ECU) which calculates fuel delivery.
    A hood scoop will not add much unless the following are considered:
    1) Aerodynamics. Depending on style of the scoop and its location, it could be useless.
    2) Metering. If your MAS is only capable of metering certain amount of air, it does no good to provide more air than what the MAS can measure.
    3) Assuming you do have a functional scoop, on a naturally aspirated engine you will not get a ram-air effect unless the vehicle is moving at a very high rate of speed. In other words, little to no low and mid range performance gain... and in a overweight truck like the VX, marginal high end gain because you can't get the VX moving fast enough to matter.
    O2 sensors are found along the exhaust system. Their purpose is to monitor fuel mixture and exhaust emissions.
    Who says tight corners are not the VX's forte? You must be doing something wrong behind the wheel. The VX has a shorter wheelbase than most sports cars. It's all a matter of learning the VX's handling dynamics and adjusting your speed and steering to accommodate. Look at the VX, it is a body on ladder frame truck. It is not an Italian Autostrada speedster or grand tourer! Stiffer antisway bars will change vehicle dynamics. If you don't know what you're doing you could end up with a VX that is even more tippy than stock. Proper stiffness/flexibility actually allows proper weight transfer and tire to ground contact to help you negotiate corners. With the short wheelbase and too stiff of a bar, the rear will tip rather than kick out (oversteer).
    I am willing to bet neither Calmini nor Hellwig spent time to figure the VX's handling limits when they designed their sway bars. I doubt they had the budget to crash a few $30 VX's to find the sweet spot.
    Yeah, what paul said! Tires ARE the weak link on a stock VX - put a decent performance tire on like the Pirelli Scorps and handling improves markedly. Handling is one of the things the VX does best, especially with the stock shocks and sway bar combo. Stiffer bar might make it better at some manuevers and worse at others. It is a rare vehicle that handles as well as ours and yet offroads as strongly - I don’t believe there are any.
  1. Aftermarket exhaust
    Last Post: 11/05/2015, 08:44 PM
  2. Aftermarket parts
    By FlyingV77 in forum VX Talk...
    Last Post: 10/21/2009, 08:25 PM
  3. Aftermarket Warranties?
    By snowtrooper1966 in forum VX Talk...
    Last Post: 10/30/2008, 04:10 PM
  4. Aftermarket Parts
    By Solitude in forum VX Talk...
    Last Post: 12/20/2007, 05:39 PM
  5. aftermarket ECU?
    By ddsheep in forum VX Modifications...
    Last Post: 06/11/2007, 03:37 PM
