Results 16 to 30 of 45
Thread: 5-Speed Swap Info
  1. #16
    Sep 2003
    `99 Astral #1889 (sold) | `95 Trooper TeraLows-5.38s-35s | `98 Acura SLX
    I have a 1997 Rodeo w/ MUA5, and a 1999 VX…
    The firewalls are 100% IDENTICAL – including the fact that the VX has a (plugged) pass-through for the clutch/master cylinder assembly, including the mounting holes… No drilling necessary.
    I intend to swap the Rodeo’s MUA5 /w integrated T-case into my VX someday… and I think I’ll be able to live without TOD since I’ll be gaining a set of 3.07:1 ratio Tera Low Gears (already installed)
    "This trail is so bumpy, it's knocking my bra straps off!" - Miss Kathy
  2. #17
    May 2008
    Quote Originally Posted by kpaske View Post
    Great info, TS, thanks for sharing! I have often daydreamed about doing a complete drivetrain swap in my VX. We've discussed in some other threads the possibility of dropping in a turbo diesel / 5-speed combo from a Trooper, and if I only had the time and expertise I would have done this long ago (BTW if there are any volunteers out there, I could be open to the idea of paying/bartering/trading or whatever for some help! ). Have you considered anything along these lines?
    baby steps... swapping out the most complex part of a vehicle is a LOT of work.
    there are a ton of things to consider too
    People obviously consider stuff like
    -will it fit?
    -will I have to have a custom drive shaft made
    -will the gearing work?
    but what about..
    -will I have to fabricate custom engine and transmission mounts?
    -will the factory radiator have enough cooling power
    -will I have to make custom radiator hoses?
    -will I have to make custom power steering hoses?
    -will cruise control still work? what has to be done to preserve it?
    -will A/C still work? what has to be done to preserve it?
    -will the current fuel system support diesel or will I have to upgrade the pump, filter, regulator, and lines? Will the current lines even plug into the new engine?
    - lots and lots of other tiny details
    being that you're going from an isuzu to an isuzu you'll probably have an easier time over all, but moving to some engine from another make and model altogether, you're in for a LOT of work.
    I'm in the early stages of swapping an LS1 into my Nissan 240sx and let me tell you there are a LOT of tiny details, little crap that you don't even think about like... hmm I need to use an adapter to hook up just about EVERY hose, the wiring harness is about 6" too short so I have to cut and lengthen EVERY wire on the harness. or the fact that while the motor fits the headers do no... oops there's another grand I wasn't planning on spending.
    I looked at the MUA5 transmission because it's made to work with that motor, in a similar chassis. If Isuzu had built the VX in a 5-speed they probably would have chosen that transmission as well... is it the best transmission? no, there are lots of other transmissions I'd like to use first but it's the path of least resistance, you're probably not going to find a cheaper/easier 5 speed to swap in, and it's an upgrade from the auto trans that's in there now...
    Anything is possible, it's just a matter of resources.
    I'm planning on looking into this swap more seriously in the spring... hopefully my LS1 project will be done by then and the bank will have some spending money.
  3. #18
    Sep 2008
    None, yet...
    Hi,
    New guy here thinking about buying a vehicross and putting a 5sp in it.
    What about the possibility of mating the TOD to an Aisin AR-5 (MA5) out of a 4WD Colorado/Canyon/H3?
    Does the TOD "talk" to the TCM at all or just the ECM?
    I think the bellhousing is the same as a 4L30, but I could be wrong.
    more info here: Link
    Edit: now looking at it, it appears the starter motor is in a different possition. I can't tell from the picture, but I wonder if the the bellhousing is part of the transmission case or if it is two pieces. Wikipedia claims the AR-5 came on some Troopers/Bighorn.
  4. #19
    Sep 2008
    None, yet...
    Upon further investigation, the AR-5 is based on the 15X series of Aisin transmissions. Apparently the bellhousings for these will all interchange, so it should be possible to mate it to the 3.5l Isuzu.
    More info here: Link
    Now, can an adapter be made to mate the TOD to the transmission and is the output shaft of the trans the same size/splines as the TOD?
    Does anyone have size/spline info for the TOD?
  5. #20
    Apr 2007
    2001, Proton #1238
    As far as I know the TOD will only work with the automatic. The TOD and the automatic transmission computer are one in the same.
  6. #21
    Sep 2008
    None, yet...
    Thanks for the response! So to retain the TOD would require a dedicated TOD controller, which is probably what the rally cars are using. That would not bother me, if one was available... time to pop over to the TOD controller thread and ask some questions there....
  7. #22
    Sep 2004
    1999, Astral Silver, VX, 0938
  8. #23
    May 2008
    coachreed attempted to keep the TOD system on his LS1/T-56 swap
    IIRC he had to crack open the transmission to swap out the output shafts and have a custom adapter plate fabbed up to mate with the TOD system... I suspect you'd have to do the same to get any transmission to work with the TOD system. I have no idea of what was done on the computer side to get it to work.
    I realize that the TOD system is part of what makes a VX a VX but really it's just a electronically controlled AWD system. I wouldn't be surprised if the rally VX dumped it altogether in lieu of full time 4WD.
    Considering there's a lot of effort to turn the TOD system into a manually selectable 2WD/4WD system I wonder why even bother keeping it?
  9. #24
    99 Silver VX
    Yes the hummer H3 5 speed will work..(belhousing change). as will the factory H3 low 4.3:1 transfer case that is in the H3!!!!!.....Ive done much exstensive research on this and will be doing this exact swap soon...
    the TOD computer is SEPERATE from the computer that runs the auto tranny!!!!! And it ONLY operates the TOD.
    Also the H3 transfercase is built just like the VXs and is in fact also of "TOD" design meaning elrectromagnetic clutches that engage 4x4....
    Lastly, You CAN mate up a ar-5 out of a 1999 trooper to a stock VXs transfer case. AND keep TOD..they bolt right up!
    another possibility is the 6-speed out of the FJ cruiser (belhousing change to ar-5) mated to the H3 transfer case!
    This has been spoken on before a while back....
    Go for it.....
  10. #25
    Dec 2007
    2001, silver, 0676
    im just bookmarking this thread so i can view it when my vx doesnt have 24k miles haha...sort of a future modification
  11. #26
    Jan 2008
    Formerly 2000 Kaiser #0486
    Auto W/o tod?
    Not meaning to thread jack but what are the options of just ditching the tod case then? I like the auto trans i just want the tod gone to make my sas easier to work out? Would i just need a xcase out of a rodeo or would the H3 case bolt up? I'm confused here. I just don't want too much custom fab on this part since the eventual sas has plenty. If the tod computer is seperate from the tranny that'd lead me to believe it can just be replaced with another case and i can keep the auto trans. It'd make it a little cheaper to do as well.
    nznsi
  12. #27
    99" silver Vcross #1307
    Tod
    Just did alot of research on the subject and the trooper has two more switches 4wheeldrive and a TOD switch somone has the scamatic here on this site shows the difference between the two check it out, and yes it can be done. Manual drive needs the two switches cause its a manual,
  13. #28
    1997 Silver JDM 0623
    I see no reason why a rodeo transmission wouldn't fit straight in - here in the UK we have the Frontera with the Isuzu V6 same as the JDM VX - having examined the whole transmission i have discovered that a donor manual V6 frontera transmission would bolt straight to the VX power unit - the frontera transmission is SOTF like the JDM VX so giving 4WD by button and low range as well
    surely a US rodeo V6 is the same as a frontera and a rodeo ecu would fit the VX as a swop sorting out the auto transmission problems
    the transmission comes with a 'dual mass' flywheel and handles speeds up to 130 mph easily
    cheers
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
  14. #29
    Jun 2007
    Looking for another...
    I am subscribed to this now. I want a bad *** 5/6 speed vehicross and still retain TOD.
  15. #30
    Feb 2009
    2001 Yellow Vehicross 0452
    Yo,
    I'm Brand new to the forum, but this is one of the only things I consider to be flawed about the VX. I have decided that when my Auto Transmission begins to crap out I WILL be replacing it with a manual. Given the surprises that my VX throws at me this could be tomarrow or it could be a year from now. An earlier post stated that the ar-5 could be bolted in. Would I need a new bell housing and/or a TOD adapter if it came from a 1999 Trooper? My goal would be to keep the TOD system.
  1. VT_Maverick's 5 Speed Swap
    By Buffy in forum VX Talk...
    Last Post: 01/09/2016, 01:45 PM
  2. ATTN!!!! 5 SPEED SWAP W/TOD DONE!
    By BigMeatVX in forum VX Modifications...
    Last Post: 06/01/2015, 04:48 PM
  3. Speed O off
    By Heloavi in forum VX Troubleshooting...
    Last Post: 11/10/2014, 07:14 PM
  4. Gear Swap Info
    By kpaske in forum VX Modifications...
    Last Post: 04/03/2005, 11:38 AM
  5. Top speed?
    By MZ-N10 in forum VX Talk...
    Last Post: 11/07/2003, 03:42 PM
