Results 1 to 6 of 6
Thread: Tow Hook Replacements
    Oct 2004
    99 Astral VX 1032
    Has anyone found a replacement for the front tow hook? I am not refering to another hook, personally I don't like hooks, I would prefer a full loop or ring. Trying to see if anyone has one that will fit both front spots on the Vehicross.
    Ryan Christiansen
    Trooper Skid Plates, OME 912's, Stric9 Sliders, Load Warrior with extension, Apline sub in rear door, Apline front speakers, Alpine head unit, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Manual Hubs.http://picasaweb.google.com/RyanVehiX
    Quote Originally Posted by NJ99VX View Post
    some of the troopers and rodeos had hooks that have small spring clips to make sure nothing comes off and i know they fit.. thats all i have seen/heard of
    Lightbulb
    You could get these: http://cgi.ebay.com/U-Weld-clevis-mo...d=p3286.c0.m14
    and modify them to fit, by welding them to some 1/4 or 3/8" plate steel, drilling holes in the appropriate places & bolting them to the stock hook location(s). Then hang clevis loops of your choice...
    I would cut as much length as possible off them before welding to the brackets, maybe even angle them back a little to keep as much approach angle as possible.
    Aug 2008
    I saw that "LITTLE BEAST" had twin chrome tow hooks on the front of his VX. Just click on the "photo gallery" of LITTLE BEAST, and you will see some good photos of the twin tow hooks in place. Twin hooks to match the twin fangs in the grill. Looked pretty decent!
    iirc they didnt fit properly and were only attached with one bolt, i think he removes them and puts the stock one back on for offroading
    Oct 2004
    99 Astral VX 1032
    Anyone up for fabbing some recovery points up? I like the pieces LDUB posted from ebay, but they are way too think. they probably shouldn't be hard to make, a flat piece with two bolt holes in it, and another piece welded to it forming a 90 degree angle with the curve and hole in the end. I do like the idea of them angled a little, maybe a gusset in between the bolt holes for sideways pulling resistance?
    I can't weld, so I am out. I can't find anyone around here that fabbs stuff up that will return an e-mail either. I need two, one for each side.
  1. Spare hook
    By BOARZHEAD in forum VX Talk...
    Last Post: 05/10/2011, 07:08 PM
  2. Rig of the month....Mr. Scary Hook...!!!!!
    Last Post: 10/08/2009, 07:18 PM
  3. front tow hook
    Last Post: 04/24/2009, 10:10 AM
  4. bulb replacements
    Last Post: 12/24/2007, 09:41 PM
  5. 18X7 or 18X8 replacements?
    By driver3 in forum VX Talk...
    Last Post: 09/23/2004, 03:50 PM
