Hi all,
After power-washing my engine bay a couple of weeks ago, I developed an intermittent rough running condition, which ended up throwing Check Engine code P0302 (#2 cylinder misfire) twice. I figured I got some moisture in or under the #2 cylinder coil and it is shorting out or something. I ordered a new coil pack from Autozone ($95), which I will try to install tonight. The VX is not at home - it's at a "remote" garage - so I want to make sure I bring every tool and material I might need for the job with me.
What do I need to do to remove the old coil and replace it with the new one?
I saw that there are some Philips-head screws holding it on, but other than that, what tools might I need? And should I pull the spark plug while I'm at it?
Thanks!!
