Results 1 to 5 of 5
Thread: How do i remove the spark plugs?
    Nov 2006
    1999 White Ironman
    Engine novice. I couldn't find this anywhere. The spark plugs are way down in there, how do I get them out/what tool do I need?
    Thanks for your help!!
    Jun 2007
    2001, Proton
    search under tune up
    I asked this before and got an excellent howto They are a bitch
    They are a bitch
    Especially the back right one. Have fun!
    2001, Dragon Green, 1342
    It's really not that hard. remember,.... Lefty loosey, righty tighty.
    You will need the right size socket of course. You will also need a torque wrench so that you can tighten them correctly. BE SURE to use a anti-seize compound so that you get the right torque. This is applied to the threads.
    You will also need the right grease to put on the ceramic of the plug and spark plug boot so the next time you will be able to remove them. You can apply that inside the boot with a Q-Tip.
    The correct torque is: 13 lb. ft., 156 inch pounds
    If any other questions/problems, feel free to contact me
    Nov 2006
    1999 White Ironman
    Thanks Everyone!!
  1. Mileage and Spark Plugs
    By blacksambo in forum VX Troubleshooting...
    Last Post: 04/23/2011, 09:40 PM
  2. spark plugs
    Last Post: 04/07/2010, 10:15 AM
  3. Spark Plugs
    Last Post: 02/06/2010, 03:12 PM
  4. Best Spark Plugs...for Gas Mileage?
    Last Post: 05/13/2008, 06:49 PM
  5. what spark plugs are you using???
    Last Post: 06/26/2007, 06:47 AM
