im fixing my friends car and just wanted some advice. Hes got a tahoe and has had some 22"s on it for about a year. Recently hes been hearing a grinding sound from the drivers side, especially when turning left. its gotten so bad and lound now he doesnt want to drive it. I took the wheel off and when i try to turn the disc it makes the noise hes been hearing. it sounds like a grinding and feels very cluncky. also as im turning it, it sometimes will lock up and require a good deal of force to get it turning again. there is also a tiny bit play. does a bad wheel bearing present like this? Thanks guys
if it's got big tires you need to REALLY beat on it (don't be shy, remember it holds the lateral weight of the vehicle going around a corner) it should be rock solid with no noticeable movement.
