View Poll Results: has your abs pump/module made your abs light come on?
Voters
153. You may not vote on this poll
  • yes
    110 71.90%
  • no
    43 28.10%
Page 7 of 7 FirstFirst ... 3 4 5 6 7
Results 91 to 99 of 99
Thread: question and poll regarding abs module
  1. #91
    Jan 2010
    2001 black 1145
    abs fixed
    Got a used abs module (came with pump) for a 1998 Trooper, put it inot, everything works fine
  2. #92
    Nov 2003
    '99 Ironman 1405
    Quote Originally Posted by Daly View Post
    Good to know. Thanks for the info. Where and how did you find it? What did it cost you?
  3. #93
    disasterlady Guest
    Wrench ABS fix
    So my ABS module went out and I am wanting to do the ASI repair but after reading all of the posts... I'm confused. Is the car drivable and you don't have to bleed the brakes IF I JUST REMOVE the black electrical module and send that off to them?
    thanks guys
  4. #94
    Quote Originally Posted by disasterlady View Post
    thanks guys
    Yes that is the case.
    This is how I did mine.
  5. #95
    disasterlady Guest
    Thanks Mile high.... I now have to see if I can tackle that removal! Looks daunting from the posts.
  6. #96
    Yah, it has to be that way. In case the ABS fails, your brakes still need to work.
  7. #97
    Nov 2003
    '99 Ironman 1405
    Angry Many hours to remove 1 ABS module T20 screw
    Just for laughs from folks that possess magical under-the-hood abilities, I estimate it took me many hours to finally remove that one screw. Five of the six screws were no problem, but the one in the lower left side (nearest the passenger side wheel well) was a heck of a challenge. All kidding aside, reaching that "hidden" screw caused me to contort myself into ways that resulted in painful back strains. Power to the VXers that were able to remove their ABS module within minutes. As far as I'm concerned those folks must possess superhuman abilities.
    I will permanently affix a 2" extension to the head of that one screw to eliminate that access problem in the future.
  8. #98
    Nov 2011
    1999 Ironman 1515
    I just changed mine out. At first I thought it would be hard to get at that torx screw, but I just unscrewed the two nuts on either side of the ABS module and it pulled up enough to put the torx driver directly on that last screw. It also made it easier to put it back on(5 minutes), and attach the plugs.
    Mike
  9. #99
    Nov 2003
    '99 Ironman 1405
    Quote Originally Posted by Makocross View Post
    ...but I just unscrewed the two nuts on either side of the ABS module and...
    I chickened out after loosening those 2 nuts, because it felt like the brake lines might be damaged. A post recommended spraying the brake line plastic clamps with WD-40. Almost immediately, a small piece of a clamp snapped off when I tried to remove a brake line from that clamp.
    Non-vehicle related shortcuts seem to work like a charm for me, but shortcuts related to a motor vehicle turn into grueling nightmares.
  1. isuzu axiom intake module question
    By djvx in forum Chit-Chat ...
    Last Post: 12/24/2010, 06:46 PM
  2. ABS Module
    By haggisgood in forum VX Troubleshooting...
    Last Post: 02/19/2009, 02:25 PM
  3. ABS module, how much??!
    Last Post: 10/02/2008, 08:42 AM
  4. ABS module
    By WiSDoM in forum VX Troubleshooting...
    Last Post: 09/01/2007, 03:26 PM
  5. TOD Module
    By WiSDoM in forum VX Talk...
    Last Post: 06/30/2006, 10:26 AM
