Results 1 to 2 of 2
Thread: Another Window Problem!!!
    Dec 2007
    2001,Yellow Proton, 0534
    Hi all! I know this is an old issue but I'm still having problem with both my windows. It goes down fine, but going up is the problem. It tilts forward, both windows. I removed the door panel and checked the plastic holder and it is still intact. No problem with the regulator/motor. I noticed that the front track/rail is pinching the glass when it goes up making it tilt forward. I lubricated it with a silicone spray like most of you recomemded but it is still doing the same problem. I read from one of the threads that you need the bend/twist the glass run back to position, because it bends in the long run. Would it be safer if I just replace the glass run rubber? How do I bend the metal rail if I have to? Any good advise will be helpfull.
    2001, Dragon Green, 1342
    This is a problem that I think every VX has had. User SBC has produced a bracket for us that is a simple and seems to be a permanent fix for this problem. It is a simple repair. http://www.vehicross.info/forums/sho...&highlight=SBC
    If your leary of getting into your door, I wrote up a how to for getting into your door insides. http://www.vehicross.info/modules.ph...warticle&id=22
  1. A Different Window Problem
    By fotomaker in forum VX Troubleshooting...
    Last Post: 08/09/2014, 11:27 AM
  2. window problem
    Last Post: 04/15/2012, 08:45 PM
  3. A weird window problem
    By ameetw in forum VX Troubleshooting...
    Last Post: 10/18/2008, 11:19 AM
  4. window tilt problem
    By zzzyang in forum VX Talk...
    Last Post: 02/28/2004, 05:08 AM
  5. VX Window Problem
    By VX Monster in forum VX Troubleshooting...
    Last Post: 07/29/2003, 08:20 AM
