Results 1 to 7 of 7
Thread: front wheel tod flashing
    1999 silver 1346
    my lights on my front whee tod fully come on when i am going slow.and.hittong the brake. any ideas why. when i come to.a.stop it goes off and when.i.drive its mostaly normal but when slowing.down it comes on
    my first guess would be an abs sensor going bad.. iirc the tod uses them to figure out when to kick in
    1999 silver 1346
    any idea how tO check that? will that cause any problems later?
    have you had any issues with your abs?.. you could start by looking in the manual to find the locations of the sensors and just giving them a good visual inspection, i know some of them are magnetic and can attract small metal shavings that could affect how well the work
    also have you double checked your tire pressure to see that all 4 tires are identical?
    1999 silver 1346
    i recentaly replaced my abs module. but this also happenswhen i am not hitting the brakes/ the tires are ok.
    Try to locate the ABS sensors themselves at each wheel and trace the wiring back as far as you can. Check each connector that you find & clean it. Suprising how often it's the simple things.
    Oct 2011
    2000, Black, VX, 0055
    Exclamation 2000 VX 72,000mi
    ya i just came up with the same problem yesterday when i got the VX stuck in my pond!!! it started idling high while i was pulling it out with another truck the engine also cut off by itself a couple times a while after. but the same problem with the TOD lights flashing and feels like its stuck in 4 wheel, well TOD just not functioning properly and my abs light has always been on so ill check that first and post my results
  1. front wheel well difference
    By HuzpazA in forum VX Troubleshooting...
    Last Post: 03/10/2016, 05:50 PM
  2. Front Wheel Bearings
    Last Post: 06/02/2012, 06:51 PM
  3. front flasher - turn signal not working, no power - rapid flashing of rear
    By atilla_the_fun in forum VX Troubleshooting...
    Last Post: 03/17/2011, 06:38 PM
  4. Front Wheel Bearing Re-Pack
    Last Post: 09/25/2006, 10:51 AM
  5. Front wheel center bore
    By Bimati in forum VX Troubleshooting...
    Last Post: 07/30/2006, 06:22 PM
