Results 1 to 15 of 15
Thread: VehiCross High Mileage
    I'm looking to buy a VehiCross but wondered how many miles this thing will run for.
    Could I expect to get 150k miles without any major repairs.
    I've heard some good reports about high miles and extremely low maintainance. But need more actual proof.
    Jun 2005
    01 Dragon Green VX 1286
    might do a search on oil consumption
    ex 1999 ebony black vx 1979
    Mine has just shy of 157 k with nothing major.. typical window issues, egr needs cleaning once in a while and its thirsty for oil but all in all the best vehicle I've ever owned.
    Oct 2006
    2000, Green, Vehicross, 0054
    at 96k and no issues, yes, oil consumption is something for which you should be on the lookout, but otherwise, running fine
    service is relatively cheap as well, at least with respect to my Audi's (imagine that...)
    That's a hard question to answer.
    Pride of ownership tends to outweigh longevity here. The vast majority of the owners here tend to perform preventative maintenance at a much higher level on the VX than they do for their other toys so the VX's seem to be holding up quite well for the most part. Is the longevity because of it being a well built vehicle or because of the TLC???
    There have been some seized engines, some trannys go TU, some ABS issues, some EGR issues - but I don't think that they are outside the 'norm'.
    i got my vx at 39k
    its now approaching 74k
    its been to the dealership exactly once.. for an ABS light and a front bearing repack (which i could have done myself if necessary)
    the abs issue was never resolved.. but im feeling motivated today so i may just take care of it today.. the dealership quoted me 3000 to replace the abs module.. i picked up a used module for a hundred bucks and will spend about 20 on brake fluid... time will tell how long it takes to do the install though
    other than that.. i have had to replace my fuel pressure regulator, 1 headlight bulbs, 2 fog light bulbs a tail light bulb and 3 pcv valves probably 6 quarts of oil burned between changes
    the only other issues ive had came from fixing what wasnt broken until it was broken
    "the only other issues ive had came from fixing what wasnt broken until it was broken"
    & the labor involved with sorting the thousands of pix taken of every turn of the wrench???
    well..yea... that was a given..
    It's just been a while since I 'rattled your cage'
    I just rolled 80k. Everything is good, except for burning oil and a dead ABS (which does not bother me in the least). I have a diff seal leak which I am also shamefully ignoring at the moment and another weird issue that has existed since 35k but does not seem to cause any trouble. Other than that, she runs great and I hope to get to 150k myself.
    If you are going to buy a VX, I would say you should be ok with one in the 80-90k range, just do not be hasty and maybe try to find once in stock condition. In a year or so there is a really good possibility I will pick up a second VX...I just can't imagine driving anything else really.
    Jun 2007
    2001, Proton
    except for a chronicly leaking
    axle seal mine has not required anything major
    Oct 2006
    I forgot to add about the abs module, that tends to go bad on this particular vehicle too
    I've seen some VX's that are dogs and then some that were really well cared for, to me, it seems this is more evident with VX's than most other cars
    Due to some parts issues (trim pieces), I would spend the time to find the best condition VX you can find, even those aren't too expensive
    '99 Ebony VX #0038
    I've got over 110k on mine and I've never done anything really major - just everything you would expect like the timing belt and other scheduled services, and a few unplanned issues like the windows and ABS. I think most vehicles nowadays can easily go to 200k if they're properly maintained, but if you really want something that's super "low maintenance" i suggest looking at diesels. My Jetta TDI gets an oil change every 10k, and needs very little else (except for that expensive tranny service every 40k grrrr!)
    Sep 2004
    1999, Astral Silver, VX, 0938
    Got my VX at 70k and some change, It's clock is at 148k now. Pulled OEM shocks and installed Rancho 9000's, A couple battery's, 2 Fuel pumps ( I just installed a Bosch w/lifetime guarantee, spend alittle extra and get it ) Timing belt at 95k and water pump while I was in there (the original was ok, just alittle PM ) Tweak the right window track and lube both a few times a year, with no major mechanical issue's, I feel I contribute that to this forum and the knowledge of it's members for preventive maintenance issue's. Mainly running pure synthetic fluid everywhere possible which was one of the first things I did 5 years ago and have stuck with ever since.
    Nov 2008
    1999,SILVER,VEHICROSS,1270
    Thumbs up 75,000 mls
    I bought mine with 75,000 miles on it in 2001 now iam at 130,00miles with no real problem,so far just the window issue,abs light on egr replacement still love like i just bought it peace.
  1. High Res VehiCross Logo Needed (or vector graphic)
    Last Post: 06/29/2013, 12:12 PM
  2. high mileage vs synthetic oil
    Last Post: 07/10/2009, 05:06 AM
  3. Replies: 18
    Last Post: 07/24/2008, 05:17 AM
  4. High idle/ high power steering pressure?
    Last Post: 09/22/2007, 03:21 PM
  5. Replies: 7
    Last Post: 08/03/2007, 05:33 AM
