Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
Thread: P1404 CEL tonight...
  1. #16
    Another year and another EGR code pops on. I am literally changing that EGR every 6-12 months. Can this be a constant false alarm? I've cleaned them, I've replaced them. All the same. Buying a new EGR should not be a part of normal maintenance. Anyone have a clue why?
    THIS WE'LL DEFEND
  2. #17
    2000, Ebony, VX, 0370
    Thanked: 12
    I don't get CEL codes from my EGR, but I do have it cleaned out every other oil change just to be safe. I think that they eventually just get clogged up again, so even though it shouldn't be, EGR cleaning is part of my "regular" VX maintenance.
  3. #18
    Feb 2009
    1999,silver, 1516
    I believe mine keeps an EGR code. My CE light is either burned out, or the bulb was yanked by a PO. The EGR code is easy to live with if you don't know it's there.
  4. #19
    Jun 2007
    2001, Proton
    From my experience
    This is EGR light since buying it new in 2002. There is something that is the EGR to foul quickly. Anything from poor spark to bad gas to a leak of some sort
    Carter Pewterschmidt
  5. #20
    Jul 2012
    its pretty cheap and easy to clean the egr.. i think the gasket i ordered from merlin was like 8 bucks.. and turned out to really not need it.. but i replaced it since i had it anyway..
    i had an EGR related CEL last month.... it was easy enough to clean...
    disconnected wires on top (one plug)
    used socket w/ extension to remove two bolts (one is easily visible, the other mirrors that but its hard to see)
    lift top part of EGR valve off and set aside upside down filled with sensor safe carb cleaner
    plug the larger of the two holes now exposed in your engine bay
    start the vx
    spray carb cleaner into the remaining (smaller) hole a whole lot until you run out of carb cleaner or get really bored.. just take care not to stall the vx..
    dump the carb cleaner out of the half of the EGR you removed.. spray it down a couple more times to get anything broken loose out
    put your egr back (dont forget to unplug the hole)
    bolt it in place
    be sure to wash your hands before touching your leather steering wheel
    I just did this yesterday and cleared up my P0401 code! Thanks for the super easy fix! My mechanic was going to charge me $385 to replace it. I asked him if it could be cleaned and he said no because it has electrical parts in it and it would be ruined. I knew there was a fix around these forums somewhere, and after checking, am so glad I saw this simple fix.
  6. #21
    While you are at it, take the time to pull all of your spark plugs & check the gap. When I cleaned the EGR on Boy's VX, it was clean but I found the gap on all plugs were at 50/1000 or more. I'm guessing that if it continued to run that way, it would probably have fouled the EGR eventually.
    The PCV was completely clogged on it too. That can also lead to EGR fouling over time.
    One last thing to check if your EGR keeps fouling is the CAT. Take it in to a Midas shop (or similar) & have them check your exhaust system. Too much back pressure will also clog the EGR over time.
  7. #22
    Jul 2012
    Thanks for that info, Tom. If I throw another EGR code, I'll do that. My mechanic recently(within the last 5k miles) did a timing belt/water pump/spark plug service to it. What is the gap supposed to be at exactly? I could always check that sometime.
  8. #23
    EGR Success story
    My VX popped a P1404 (and another code I don't remember) a week after my trip to North Carolina in September. I cleared the codes thinking it may be due to the constant rain on the drive home. Nope. After only 5 or so miles the P1404 returned.
    I stopped by Autozone and bought a can of carb clear to prepare for the first attempt at resolving the issue. But, when I pulled the EGR valve off, if was completely clear. No build up in either the EGR tube or the pintle. Hmmm. I cleared the code again and it didn't return for a few weeks.
    Yesterday I finally took a drive to the grocery store and the code returned. I came home, did some research, and chose the NAPA EGR (CRB226154) as my replacement candidate. Sure, it was more expensive, but it looked like really good build quality, it was in stock, and it wasn't Autozone, Pep Boys or Advance Auto Parts! I bought the EGR and five minutes later I was back on the road.
    I decided to duplicate my previous trip to see if the code would return. Sure enough, I pulled into the Wal-Mart parking lot, read the codes and found a P1404 (pending) code. Damn! I didn't even stop. I drove back to NAPA, explained the situation, and asked if I would be stuck with this EGR. The nice lady told me to bring it back later in the week ("It would look bad if you returned it today") and she would refund my money.
    So, I left NAPA, with the scanner still connected, and tried to clear the codes while sitting as a red light. "Confirm key one, engine off". Can't clear the codes while driving. Two minutes later I was home, hit the Read Errors button, and NOTHING! No more codes. I retraced my steps AGAIN, even stopping to shop at Wal-Mart, and codes did not return. Apparently, there were some old fault readings still in the buffer from the old EGR, and the system just had to clear them out before giving a clean bill of health. My VX is back whole again!!
    To make a long story short... If you replace your EGR make sure you give it plenty of miles to clear the old fault readings before you read the codes.
    Gregg
    2001 Proton Yellow #1379
  9. #24
    My CEL returned on my recent trip to Georgia. I actually got three different codes during my return trip (P1404, P0405, and one other non-EGR related), plus my GPS refused to power back up immediately after I got the first CEL. And then, in the mountains, my tranny/transfer case was acting up, vibrating badly when I dropped my speed from 75 to 65, and then running smooth as I sped up or continued a few miles. All of these concurrent issues made me suspect an electrical problem, and not an EGR issue, which was supported by the the 5 year old battery and corroded battery terminal. Today I replaced both the battery and terminal, but I still got the CEL and code P0405. I cleared the codes several times. As a troubleshooting step, I removed the EGR and reinstalled my old EGR valve, but this time I also replaced the gasket. The old gasket still looked good, but I had a new gasket. Then I took the VX for 10 mile drive, and didn't get a CEL, but I had a "pending" P1404 code, the same code that drove me to replace the original EGR valve. I'm going to drive it a while with the old EGR and see if the CEL pops up. If so, I will reinstall the new EGR with a new gasket and see if that returns a code, same or different. This is very frustrating!
  10. #25
    Jan 2010
    1999 Astral Silver
    I've had EGR code come up and clear out on their own for a long time now. Went through 3 EGRs (currently OEM one) all O2 sensors and replaced PCV with catch can and replaced fuel filter. One of the codes that came up with EGR code was "lean during acceleration" and that led me to clean my MAF sensor and replace K&N filter (the one with oil on it) with basic air filter. No codes so far but i have a totally different issue now and only drove about 30 miles after cleaning MAF. However i am optimistic about EGR codes because they would show up well before 30 miles in previous iteration
  11. #26
    I'm convinced it is the TIRES! Based on scientific probability analysis...
    When I drove to NC in September I was on my Khumos...result=CEL.
    Then drove to GA in December on my Khumos...CEL.
    However, I switched over to my Bridgestone Blizzak tires for my trip to PA, and left them on until last week...no codes!!
    BUT, on my first drive after changing the tires back I get a handful... P0405, P1404, P1404pd..
    Yes, it's the tires!!
  12. #27
    2001, FoxFire Red, VehiCross, 1267
    I have been having trouble with the EGR codes for a couple of years. I finally broke down and installed a new EGR valve and cleared the codes. They quickly returned. A few weeks later, for completely different reasons, I added 1 quart of Marvel Mystery Oil (MMO)to the engine. The engine has been running much smoother, my gas mileage has gone up from 12.5 mpg to 15 mpg and......the engine codes have all cleared. No codes for about a week now. Crossing my fingers. Still burning/losing oil. I plan to let the MMO sit in the cylinders for a couple of days, next time I have a weekend while I won't need to drive the VX.
    Jason White
    2001 FoxFire Red VehiCross
  13. #28
    Jun 2014
    2000, Ebony, 0570
    So has anybody had this code actually clear with further driving? I cleaned the EGR this past weekend, the pintel was working fine, but didnt clean the tubes as I wasn't sure if the cleaner got in the engine if it would cause troubles. Light came back on at random as usual , however after powering through sand at the beach it went away. This normal? I'm probably gonna try cleaning the downward hole next, the manifold hole looks like a PITA.
  1. Going out to the airport tonight.....
    By LittleBeast in forum VX Talk...
    Last Post: 05/01/2009, 05:37 PM
  2. New VX tonight - need help with 4 issues
    By johnny010 in forum VX Troubleshooting...
    Last Post: 12/30/2008, 11:16 PM
  3. Man muscles needed tonight!
    Last Post: 11/07/2008, 12:24 PM
  4. suggestions for engine P1404 and P0402 codes
    By bielsubob in forum VX Troubleshooting...
    Last Post: 01/03/2007, 02:20 PM
  5. L.A. VXer's Tonight
    By Anita in forum Meets...
    Last Post: 11/30/2003, 02:13 PM
