Results 1 to 15 of 22
Thread: Green Diamond MT's
    May 2003
    Lightbulb Green Diamond MT's
    after much searching on the site about how large a tire I can run on a non-lifted VX, the results came to 31.54"-31.6".
    Well, I just got off the phone and ordered (4) Green Diamond Icelander MT's which for 16" wheels only come in the size of LT 265-75-R16. They don't give specs on their website but since the tread pattern is a clone of the Yokohama GeoLander MT, I looked up those specs and it works out to 31.9" diameter. My currently mounted Revo's are 265-70-R16's @ 30.7" with little trimming.
    Not worried about the rears but I think the fronts are going to require some more cutting and possibly a few cranks up on the torson bars. At worst, I might do what Orion did and go with 1.5"(or 2"...can't remember) rear spacers & torson bar crank.
    They are 10 ply and are "remanufactured" with a cost of $145 each. I googled MT tires to death to find something that will go good in the snow as well as mud and rocks. Here is the article that swayed me over....read up and then flame away!!!!!!
    http://www.offroaders.com/tech/AT-MT...elander-MT.htm
    http://www.offroaders.com/tech/AT-MT...o-The-Test.htm
    http://www.greendiamondtire.com/
    http://www.greendiamondtire.com/productswest2.html
    P.S.--I'm putting my original tires/wheels back on the VX and just taking my custom wheels in via my truck to get them mounted up. Then I can bring'em home and go from there with fitting them up.
    On a final note...my Revo's have performed greatly and at approx. 50k miles of wear they are still getting me through the snow surprisingly well. I was very tempted to go with another set but deep down wanted some more aggressive treads but not sacrifice snow abilities.
    Aug 2008
    Hmmm. Snow tires, eh? Perhaps looking for tires that have the "Snowflake/Mountain" symbol on the sidewall would be a good start. Take a peek at the General Grabber AT2 or the Pro-Comp A/T (both lightweight tires with Snowflake/Mountain symbol). Time to ponder.
    Yes, keep us posted. Those tires look pretty beefy and mean, and if they perform, that's a good price.
    As for fitting them, I think you should just do what I did, throw in the 912s and crank 9-10 times up front and be done with it.
    If the "icelander" tread doesn't look almost like a dead ringer for the "REVO" tread pattern, I don't know what does...
    Keep us posted on these tires performance & longevity...
    May 2003
    Wink
    yeah...snicker, snicker,...I noticed that too. The AT's are a knock-off of the Bridgestone Revo's, the C/T's (cross terrain??) not sure about, and the M/T's that I'm buying are a knock-off of the Yokohama Geolander M/T's.
    someone on another message board emailed the owner of green diamond tires about why they don't make larger tires like 33" or 35". Here is his answer:
    "At present, the largest GDTs that we build are as stated on the website. We receive many requests for 33, 35 inch GDTs on a 15 wheel and we are evaluting the availability of casings for at least the 33 for the coming 2009/2010 winter season.
    The critical issue for us is that we reject over 80% of the casings that we evaluate for remolding into a GDT. Mathmatically, we need access to 1,000s of casings just to build 100s of GDTs.
    So, regrets… nothing as large as a 35 or 36 in a 16 inch wheel in the near term.
    Regards.
    ~rich"
    http://forum.solihullsociety.org/vie...632c57eb39760d
    Here is another company I found:
    http://treadwright.com/CustomContent41.aspx
    Those tires should fit just fine with very little trimming. I ran that size AT's before the lift. a few twists of the T-bars to take the rake out of the VX will make them fit even better. I would skip the spacers though. That will just put your tires into the cladding when turning since it makes your turning arc wider.
    May 2003
    Smile
    I appreciate that you got that size to fit...although I think my offset of +10mm could make it harder....we'll see.
    about the spacers..I was meaning for the rear coil springs instead of buying the 912's. Orion did this before Moab, used spacers to gain like 1.5" to 2" of lift and he claims his ride didn't change & maintained his original handling characteristics.
    I'm still not sold on the 3" lift ( I love the look but not the fear of boots 'o' break'in along with possible cv damage). Plus, I think a 3" lift will make my new shoes look too small!
    These tires do have the "Snowflake/Mountain" symbol on the sidewall from what I see in the photo. As far as the others you listed, they are A/T's which is what I have now (Revo's). Great for alot of things but not so great for mud. The FireStone Destination M/T gets good grades for mud, snow, etc.. and was my 1st choice until I stumbled onto the Green Diamond's.
    Jun 2007
    1999 Ironman, 2001 Proton Yellow
    Thanks so much for that Green Diamond nfo. I went to the dealer locator and found a guy in New York about 2 miles away whom I always used to buy my tires from. Big Thanks again!
    I would love to hear those Icelanders at speed on a highway.
    GROWLGROWLGROWLGROWLGROWLGROWLGROWLGROWLGROWLGROWL GROWL
    "I love the look but not the fear of boots 'o' break'in along with possible cv damage"
    That isn't much of a problem now. Several members have installed the diff drop brackets & so far none have reported any CV problems.
    Ah, did not think about the fact that you are not running stock wheels! And I was thinking wheel spacers not spring spacers. I need to stop reading and responding when its late at night and I've taken cough medications!
    May 2003
    Wink
    Quote Originally Posted by Bieredalsace View Post
    That's what sharing is all about! Good luck with them...mine could be in tomorrow (Wednesday) up to Friday. I already got my Revo's & wheels loaded up in my truck ready for the call to get'em mounted up!
    LOL...Actually, for a mud tire, according to the testing on offroaders.com they claim noise is limited more in the 10mph or less and they claim they balance well for a mud tire which can be a problem. Here is a claim from their site:
    "On the Street
    During the first 1000 miles or so John, the owner of the truck, made these observations about the handling, noise level, cornering and braking of the freshly installed Green Diamond Icelander MT. First to be said, they balanced well which is good for any tire but even better for a larger MT type tire that will quickly let you know the balance is out. On the street and highway, road noise is minimal. A slight hum from the tires but nothing that is annoying, and on the contrary, sounds good. Apparently the tread pattern is good for preventing lug slap and harmonics that is commonly associated with tires geared for offroad. Dry pavement cornering the tires feel strong and hold traction well. Air up to their recommended pressure, they felt strong with good stiff cornering especially for a tire with a tall Section Height, the height of the rubber rim to ground (for more on tire definitions and descriptions see this page). Stopping traction is good on dry pavement, similar to the siped all terrain that were on the truck previous. Wet weather stopping traction required a little more distance, mainly as we gather due to the lack of sipes in the large lugs, which would make it about the same as another MT type tire that did not have sipes. As the silicium carbide granules began to appear (just under the thin layer of rubber veneer), wet weather traction on the paved surface improved as the hard silicium carbide granules found in the tire tread become exposed and compliment the tire tread compound. Since the granulars are spread throughout the tire tread depth the hard silicium carbide granules are constantly renewed for the life of the tire."
    Besides...I had a '79 Bronco with 6" lift and M/T's years ago and I'm pretty sure the redneck side of me still can handle it...
    Yeah...but your positive, alert, non-sedated opinions & advice vastly outweigh your.............................................. .other ones...
    I was under the impression those weren't available anymore...at least from Darlington. Plus..I read somewhere about front driveshaft binding causing vibration while driving???
    I came away that you have a small window to work in where you take away cv angle for the good but increase front driveshaft angle for the bad..if I understood it correctly.
    Believe me...I keep looking at Independent4X.com's lift kits & running their address in my Nav..lol. I might just crack yet..I saw alot of nice, lifted VX's @ Moab!!!!!!!!
    2 Questions for you guys:
    1) What do you guys make of the beefed up Custom Hybrid Isuzu 12 bolt w/ARB locker and 5.38 gears offered on Independent4X.com????
    2) Why did Nerv_Gas have cv problems...was it the fact he went like 3"
    suspenion lift plus 3"body lift....or was it that he went with 36" tires which seem to be 3" bigger than anybody else? Why did we hear rice krispies ???
    2001 Proton VX #0690
    Basically, the look those tires give is the only real benefit to having them unless you upgrade several parts.
    *sigh* But they look soooo goooood. I had the whole conversation with the lift-shop guy, and he basicly talked me out of lifting. It must have sucked for him to talk his way out of a sale, but I really appreciated his honesty. (Plug: It was the local Off Road Innovations.)
    I've yet to have any clearance problems, and it seems like lifting would just make everything worse -- ride, reliability, cost -- except the looks.
    But I still can't get over how much I *like* the looks... So I still ponder it from time to time... I imagine when I'm due for some new tires, I'll also start looking for some drop brackets.
    May 2003
    Wink Got my new M/T's on!
    I got home and threw the rears on first figuring I'd get the easy fit done first.
    Then I put the fronts on expecting the worst...well trimming some more off the front cladding was easy..zing...gone. But, the more pressing issue was my rock-sliders. I had to cut off about 3/8" (on each side) with my carbide cutter. I used a rubber mallet to whack the bottom, rear of the fender weld back some (I thought this would be better than a sledge because it won't leave impact protrusions like a sledge might.) I took it out for a spin and the right side was good..but the left side rubbed on tight turns most of the time. Removed left front wheel again, and pounded /cut some more.
    I probably need to crank the t-bars any way for off-road action and am leaning heavily towards a lift...but for now, on the road (and in my yard) they seem fine. They really aren't very noisy out on the road..that much I know already..gentle hum is pretty much all you hear and it mostly is at slow speeds...(that's with windows up for winter driving!)
    Going to try them in the snow today as we supposedly got
    5" over night and going to get 5" more this afternoon!
    Lookin' GOOD Man....
    Check your gallery for feedback...
  1. Green leak
    By darkside in forum VX Troubleshooting...
    Last Post: 08/11/2015, 09:11 AM
  2. Aluminum Diamond Treadplate Door sills
    By VX KAT in forum VX Modifications...
    Last Post: 03/18/2012, 04:54 PM
  3. Diamond T's
    Last Post: 09/14/2008, 01:26 PM
  4. Diamond Deckplate mod (Black Vinyl)
    By wekilled in forum VX Modifications...
    Last Post: 03/11/2007, 01:03 PM
  5. Industrial Interior: Rubber Black Diamond Plate
    Last Post: 02/11/2005, 06:56 PM
