Results 1 to 8 of 8
Thread: GM 6-lug Wheels & Vehicross
    Oct 2004
    2001, Yellow (PROTON) VX, Supercharged
    Does anyone know if GM 6-lug 18" wheels off an avalanche will fit the 01 Vehicross? I'm thinking the bolt pattern is the same but don't know for sure.
    I'm not sure if there's a difference in the actual lug diameters between the two as well. Any help would be appreciated.
    Scott in Michigan
    Jan 2008
    1999 Astral Silver 0481
    GMC wheels
    I believe they do.
    Remember that isuzu & GM are "brothers"
    I'll be upgrading my shoes next month & i was checking ebay.com wheels & tires shops & when I pull up the matching wheels most of them were fit not only GM,but toyota,nissan & mitsubishi on few SUV's models.
    Keep an eye on the center bore,which should be 100 mm for our VX's
    How ever there's so many internet shops offering wheels that you will problally spend days checking them all.
    However you can start by looking at tirerack.com
    Dakar was just the begining.
    2000, Ebony, VX, 0370
    Thanked: 12
    An old member, bimati, had some GM wheels on his VX.
    Check out this link to his gallery:
    http://www.vehicross.info/gallery/sh...user/2145/sl/b
    Where are you bimati?
    Jan 2008
    Here you go ..........
    Apr 2006
    2k Ebony
    I sold my old stock rims to a chevy silverado owner. It fits.
    Lightbulb
    IIRC, Bim had to use wheel spacers to make those rims fit, & they somehow, FUBAR'd his front bearings or half shafts...
    Anyone remember more specifics?
    As a general statement, most rims from Jap trucks (Nissan, Mitsu, Toy & Isuzu) will fit GM products because the center bore is larger. It doesn't always work the other way. Even though the bolt patterns are the same, the c-bore on many rims for GM applications is too small.
    Hmmm, see, that's weird because I always thought the 6x5.5 rims that were for GM trucks DID NOT fit because the center hole was too small. For instance, my AR rims came in both a "GM" pattern and a "Nissan, Toyota" pattern, with the only difference being the center bore....
    ya, that info is right.... most jap wheels will fit on ours (i have toyota wheels on mine)...but it doesnt go the other way (tried to sell my stock rims to someone with a T100....didnt fit....
    while on the subject, anyone know the bolt pattern on nissan armada? same as ours??
  1. Hot Wheels
    By VXR in forum VX Talk...
    Last Post: 10/04/2011, 11:01 PM
  2. wheels?
    By dtruax in forum VX Modifications...
    Last Post: 03/12/2007, 09:12 PM
  3. wheels and tod
    Last Post: 12/10/2004, 09:06 PM
  4. What Wheels to get?
    By MachineVX in forum VX Modifications...
    Last Post: 05/25/2004, 08:31 AM
  5. wheels
    By lenny in forum VX Modifications...
    Last Post: 10/01/2003, 05:49 PM
