Results 16 to 30 of 34
Thread: Wheel locks..
  1. #16
    My VX has 1 lug on each wheel that has no chrome cap & is corroded. Thought it's obviously a locking lug because there's 1 on each wheel. Couldn't find the key, searched the car completely. Used car dealer absolutely no help..."try looking in the glove box, center console or by the jack"...DOH! Like we didn't think of that! Took it to Big O tires to find out how much to drill it off or whatever they have to do....they said it was NOT a lock, just missing it's chrome cap. What's the probability that precisely 1 on each wheel would loose it's cap? Or that 4 caps would be lost and previous owner put 1/wheel? A 19mm fit but because it was missing it's cap, an 18mm fit perfectly. He DIDN'T loosen it.
    1) Big O guy said Isuzu lugs are "notoriously" bad for cross threading and then impossible to get off. Any truth to that?
    He didn't sell lugs anyway so he had no real reason to say that to sell us some, so we decided to go get 24 new lug nuts before he proceeded removing those 4 lugs.
    2) What brand do you guys recommend?
    3) What brand of locking lug do you recommend most McGard...Gorilla?
    My guess would be that the PO lost the key & the original locks were replaced with whatever they could find that would fit.
    My experience with Isuzu studs, is that the earlier (1st gen Trooper) ones were more prone to stripping than the ones on the VX.
    I only ever use a socket & ratchet (no air tools) to change mine, no problems so far & I've probably had my wheels on & off at least twenty times in the last 4 1/2 years.
    I know it's overkill, but I have three McGards in each wheel...
    My theory is that maybe it'll slow the thievin' bastiges down enough for me to catch them doing it...
  2. #17
    '99
    KAT, the part # for the nut is 8-97229-212-0. Get four new ones and they'll be a perfect match for $30-35 total. Does Tim's in Prescott or Power in Scottsdale still carry Isuzu parts? Check 'em out. They may have 'em in stock. If not, it's the same exact nut as a Honda Passport. Give the Honda parts guy that number and his system will instantly convert it to the Honda number and see if it's in stock.
    It's also the same nut on an Axiom, Rodeo, Trooper, and Amigo. If you stop by a junk yard they should have dozens of 'em.
    Mark
  3. #18
    Yeah, Tim's is the authorized Isuzu service place..1 of only 2 in AZ, we got REAL lucky with it being like 20 miles from us, and actually was a partial factor in me getting the VX...we can't fix things, (well, except for windows and lug nuts) so having the authorized place close sealed the deal for me I had my transported here from Virginia. I grew up in PGH, PA and was so afraid of rust, but the Tim's mechanic said I was in great shape as far as rust!
    Thanks for the part number, that will help. Ldub said the cross threading wasn't so much of a problem in the VX, so maybe I'll just replace the 4. When we see how hard or easy it is to get ALL of them off, I'll decide if I'm going to replace all or just the 4. NAPA wanted $98 for 24!!! I found Gorilla Acorn budge nuts-24 at sfxperformance.com for $24.90....seems too reasonable since most are around $3+ each.
  4. #19
    ive always used mcgard wheel locks, never had any issues with them.. i have been thinking of changing to spiked lugs for a cool look, and they require deep sockets to remove, so a little tougher for theives
  5. #20
    Just a FYI...I tried a set of locking lugs from Autozone a few years back, & within two days they were showing signs of rust...
    Returned em' & bought McGards...they cost more, but they're worth it.
  6. #21
    I lost the cap off of one of my lugs last February. I think water got in through a crack and then froze behind the cap pushing it off. I bit the bullet and ordered five sets of McGard lugs from Summit. The others has slight rust on the edges and I didn't want one lug to stand out. Now I've got 19 spares...
    Gregg
    2001 Proton Yellow #1379
  7. #22
    Jan 2008
    When I had the new Nittos put on the Dragon during my trip to San Diego Thanksgiving, I had locked the glove box since I had my checkbook and cash in there forgetting:
    A) the wheelock key was in there
    B) they were gonna need it
    C) they had the freaking key to the glovebox anyway!
    They never even called to remind me how stupid I was, which I appreciate tremendously. They figured it out on thier own and my dough was unmolested....
    What can I say? The eighties were really good to me
    Best,
  8. #23
    Jul 2011
    Dragon Green 2001
    Angry OK SO I have lost my wheellock key!
    I saw post saying I could get one from McGuard but don't know what to order. I am getting new tires put on in two weeks. Help!
  9. #24
    You mean you have wheel stud locks but you do not have the key? Yes, you can order one from McGuard, but you need the number that came with the key, should be in a little black plastic sleave. If you've lost both, I'm not sure you can get a replacement. You might have to have a tire shop chisel them off.
    2000, Ebony, VX, 0370
    Thanked: 12
    I lost my wheel key too a while back, and like Bart said, you will need to go to a tire shop to have them removed. They must have some kind of socket with some teeth on it that just grabs the wheel lock. It took them about two minutes to remove my wheel locks, and they didn't charge me anything. The bit that they use did put some big divots in my wheel locks, but since I didn't have the key I was going to replace them anyway.
    I got a whole set of lug nuts and wheel locks from McGard:
    http://www.mcgard.com/Applications/A...59oK1ZwQ%3d%3d
    The VX uses a cone seat style lug nut and wheel lock. I ordered the "cone seat lock" part number 24196 and they worked perfectly.
  11. #26
    Aug 2008
    Sorry to burst your bubble, Eric; but professional wheel thieves nowaday's use freon spray or a fire extinguisher to freeze the locked wheel stud ice cold and then hit the specific wheel lock with a hammer, thereby breaking the entire stud off along with the locking lug. Wheel locks today just keep honest people honest (and help you sleep a little better at night, but only a little).
    In regards to the factory OEM wheel lock "key" for our VX's--- one "key" fits ALL other factory VX's with the OEM locking lug. Fellow member "MARLIN" discovered this fact while combing over wrecked VX's in various junk yards and used his OEM wheel lock "key" to take off other VX factory OEM wheels from other VX's. Thus; if you order a "key" from Merlin of Isuzu, then the "key" you receive will fit your lugs (one "key" fits all VX's with factory OEM rims).
  12. #27
    I'm not so sure about that. When I lost my wheel lock, CrnCnn brought his over from his VX and it did not fit. I think Marlin got lucky. They probably use like 20 different ones and he just happened to have the same one as someone else....if all the wheel locks were the same, what would be the point?
    Yep...pure happenstance...
    I have three sets on mine as a "might slow them down just long enough" measure, & two of them are keyed alike. There are only so many patterns out there, no matter what McGards website says about infinite patterns, it's not economically feasible to tool up for such a large array of product.
  14. #29
    Jul 2010
    '99, Matte Black, #1870
    Yup, I had 3 sets and all the keys only worked with one set of lugs. Marlin just got lucky with his set.
    So Larry, you have 3 locking lugs and 3 normal per wheel? That should slow 'em down a bit for sure.
  15. #30
    Aug 2008
    Whoopsy; sorry gang about the mis-information about the wheel lock key fitting all VX's, as it's apparent that I was in error. It looks like I assumed based upon MARLIN's happenstance experience and we all know what "assume" means. My bad; thanx for setting the record straight.
  1. Electric Locks - Frozen?
    By kpaske in forum VX Troubleshooting...
    Last Post: 12/20/2010, 09:09 PM
  2. wheel locks
    By etlsport in forum General Tips...
    Last Post: 04/06/2007, 07:24 AM
  3. Hood Locks
    By VXFTW in forum VX Talk...
    Last Post: 01/16/2007, 04:14 PM
  4. Door Locks
    By Offroad vx in forum VX Troubleshooting...
    Last Post: 11/07/2006, 11:47 AM
  5. How to enable auto locks??
    By loco6464 in forum VX Modifications...
    Last Post: 11/14/2003, 05:47 PM
