Page 3 of 3 FirstFirst 1 2 3
Results 31 to 41 of 41
Thread: NEED HELP! Codes:P0171, P0174, P0304, Symptoms inside
  1. #31
    the fpr replacement was pretty easy.. im not sure what relay you are talking about... but the black box comes off with two bolts one on the side and one facing the firewall.. there is a fantastic write up on here somewhere, if you cant find it i think i have a pdf version of it on my computer... also try sending a pm to circmand.. i think last i heard he had the paper version of the write up and the modified allen wrench that makes things much easier
  2. #32
    Oct 2006
    1999 Silver VehiCross
    I'm going to watch this thread closely cause I just started having the same problems yesterday.....uggg
  3. #33
    2000, Kaiser, 0134
    Thanks ETL... That black box is the relay...
    I modified an allen to get to it... but it's still a pain to get to the screw facing the firewall...
    I'm still going to be dropping my VX off at the dealership, just to be safe, and possibly save me some money (replacing things that don't need it ) I'll keep everyone posted.
  4. #34
    Oct 2006
    Any update??? I'm having the same issues and no luck???
  5. #35
    FINALLY, ordered a new MAF, FPR, and EGR. Considering an alternator after all that is replaced. I am hopeful these items take care of the 171 and 174 and I will definitely post results.
    Good news. FedEX delivered my goods today so the VX will hopefully getting a mild tear down to get the goods in. FPR, EGR, and MAF all nice and shiny. I will certainly post updates on how well these treat the 171 and 174. Keeping my fingers crossed that the o2 sensors aren't part of problem.
    Wish my Green drop in filter came today, but no luck. Such is life.
  7. #37
    Well, it was a "no go". Changed out the FPR, MAF, and EGR, reset the codes last night. Drove it around all day running my errands and catching up with some friends. Ran wonderful. Really felt like she was breathing better. Upon jumping in to leave to come home this evening, she sputtered on startup and stalled a couple times in park. Next thing ya know, "CEL". Same issues as before the parts swap. 171 and 174 remain.
    I got her home and let her sit running at idle in the driveway while I tinkered around a bit more. I found that when i wiggled some wiring, the idle RPM would dance around some. I may want to look at some of the rewiring I had to do when I extended lines for the S/C install. Something may have come undone over time or something.
    I may just go ahead and add the o2 sensors to my TO DO list next.
    I am seriously losing patience (and wallet fat) with VX maintenance.
  8. #38
    May 2003
    Wink
    THAT is where I think your problems lie. I would be really looking into the wiring as it sounds like it is "imitating" the symptoms of a bad MAF.
  9. #39
    Quote Originally Posted by Jolly Roger VX'er View Post
    Indeed, it all came down to wiring. Squeezing on the TPS line/wires would oscillate the idle rpms. Plus, it threw a TPS CEL code, so that was GOOD. So, I knew where to look....
    Now, dig this....
    Last night, I tore it all down again. Pulled all vacuum lines, pulled all wiring harnesses, and removed the S/C. It appears I have found the villain playing castaway in my engine. Under the S/C plenum I found a family of well-done field mice and a handful of medium-rare babies. ALL wiring that was anywhere near that area was chewed right down to the copper. I am surprised my problems weren't 10X as bad as they are now. Luckily, it doesn't appear that they chewed on any vacuum line, gaskets, etc.
    I shop vacc'd out what was left of the bastards (sorry, I had cell phone pics but they didn't come out, heh) and cut all new wiring. Started soldering my wires again and hoped to have it all done but sadly, I couldn't find my shrink tubing, so work came to a halt.
    While on this subject, the stock wiring is absolutely HORRIBLE. Cheapest damned wire I have ever worked with. Thin, brittle, and not easy to work with. I get this crap done (and hope it solves my plethora of dodgy problems) and then it's off to solving the trannie/mode switch/clunk. *sigh*
  10. #40
    Dec 2004
    Little bastard mice!! They have caused me a lot of grief too. I'm afraid to start up the 928 each spring for fear of where they've built a nest and will the thing catch on fire once the engine warms up. I've had them in the VX, in my wife's old car, in the Mini Cooper... EVERYWHERE.
  11. #41
    May 2003
    Wink
    Quote Originally Posted by VehiGAZ View Post
    Yeah, in the past I would find half-eaten hickory nuts on top my Supercharger!
    Had baby red squirrels in my heater (blower) fan.
    Lost my underhood insulation to mama squirrel to build said nest in (blower) fan.
    I've had good success since by periodically driving it and moving it to different spots in the yard/driveway. Seems to keep the critters off balance!
  1. P0171/P0174 codes...not the MAF :(
    By twalker920 in forum VX Talk...
    Last Post: 05/22/2015, 03:56 AM
  2. Codes p0171 and p0174
    Last Post: 11/16/2009, 08:09 AM
  3. bad fuel pressure regluator symptoms
    By Vehi-Cross-Az in forum VX Troubleshooting...
    Last Post: 03/20/2009, 09:08 PM
  4. Help, my vx has confusing and aggrevating symptoms
    By JGeorge264 in forum VX Troubleshooting...
    Last Post: 10/09/2008, 06:28 PM
  5. Transmission feels wierd... Are these symptoms normal?
    Last Post: 09/15/2005, 02:50 PM
