Results 16 to 30 of 39
Thread: Easy TOD off switch!!
  1. #16
    Apr 2007
    2001, Proton #1238
    I found this index of files on the 4x4club.ru site. I just don’t know how to get to the actual downloads. My Russian is a little rusty.
    http://forum.4x4club.ru/index.php?ac...=post&id=18809
  2. #17
    Aug 2007
    2001, Proton, VX 1394
    stupid question.... (VERY STUPID)
    cant we just take out the driveshaft between the front end and the transfer case?
    i ask because i might have done some serious damage yesterday while playing and my truck sits waiting for an alternator...
    but i heard something metallic snap and my TOD check light was flashing...
    i had to go home, and after two stops (to clean) the TOD went back to normal (confused the hell outta me)
    but if i did damage something would taking that shaft out help at all
    i am sure it will make it true 2wd but a hassle to put it back in
    Richard
    Proud owner of a RWD VX
  3. #18
    Apr 2007
    2001, Proton #1238
    I was looking for some info on the JDMs and stumbled upon this little treasure trove. Take a look.
    ftp://isuzu:isuzu135@89.175.21.150/
  4. #19
    Is there a username and password that works?
    EDIT: Nevermind, I see it is in the URL there, the weird thing, is it prompted me the first time....
    Dude! Awesome stuff up there! I am dling the entire "articles" folder now.
    Great find!!!
    Apr 2007
    2001, Proton #1238
    I had to change the link. It would asks for a password if I linked strait to the download directory.
  7. #22
    Большой софт поделен на архивы по 100Мб(маленького теперь практически не бывает).
    Некоторые программы лежат в виде ISO-образов компакт-дисков или DVD-дисков,
    некоторые в виде образов программ эмуляторов(VrtualCD, Alcohol 120% и др.)
    Что за программа, какой тип образа и прочую инфу смотрите в файлах README.TXT
    в папках программ.
    Папка DOWNLOAD доступна только для скачивания.
    Папка UPLOAD доступна для закачки. Разрешено туда заливать только автософт,
    Все остальное будет удаляться. Софт будет перемещаться в папку DOWNLOAD.
    this is all i came up with when i tried the link...whats it about??
    Apr 2007
    2001, Proton #1238
    It’s a Russian FTP site. Click on the download link and you should start seeing some english.
  9. #24
    2000, Kaiser, 0134
    My plan is to have the TOD go into 2H in the way it was designed to go into 2H and not try and trick it. If the ECUs match and I figure out WTH the axel position swtch is for. I’ll start doing some test.
    The problem with that is we don't have the same hardware to go with the same software.
    We have a different system mechanically so no matter what Controller you use it won't give you 2hi. Email or PM Mbeach, he has done extensive research on this and could explain it to you way better than I could
  10. #25
    2000, Kaiser, 0134
    Good stuff on the FTP BTW...
    But who does it belong too? are they here? looks like alot of stuff from Tones CD.
  11. #26
    Apr 2007
    2001, Proton #1238
    I don’t know? I found the link on a Russian site when I was looking for JDM info.
    Quote Originally Posted by taylorRichie View Post
  12. #27
    Apr 2007
    2001, Proton #1238
    Ok, this is what I’ve found out so far. The VX TOD transfercase has the same part number as the Trooper “8-97181-309-0”. It’s also the same one used on the Aisne transmission. The TOD ECU on the other hand is different. The VX is “8-97213-467-0” and the Trooper is “8-97244-928-0”. I’m still look for good info on the JDMs. To be continued!
  13. #28
    1997 Silver JDM 0623
    From what i can read you will need the shift on the fly front axle to stop the front turning - you seem to have a standard axle on the front - which i never noticed before
    cheers
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
  14. #29
    Jan 2008
    1999 Astral Silver 0481
    what about literally changing the underneath of the VX to a trooper?? so it would have all the components of a trooper TOD??
    That's exactly what i've said.
    Just replacing the T-case,TOD ECU & front axle hardware you can acomplish the goal.
    Dakar was just the begining.
  15. #30
    Apr 2007
    2001, Proton #1238
    The ECU and the front axle are different but T-case is the same. It has the same part number as the trooper.
  1. Mode Selector Switch & Power Switch
    By ahdoman in forum VX Troubleshooting...
    Last Post: 11/20/2014, 10:34 PM
  2. Easy Task for Most of You
    By nemo in forum VX Talk...
    Last Post: 10/29/2009, 09:05 AM
  3. Easy Huh!? Shock Install help...
    By xdfarrx in forum VX Modifications...
    Last Post: 07/25/2007, 03:01 PM
  4. Easy Horsepower
    Last Post: 06/24/2004, 01:34 PM
  5. Go easy on me I'm new!
    By tritonsmoon in forum VX Troubleshooting...
    Last Post: 02/18/2003, 03:04 PM
