I've been using the calculator to check the new 9" wheels i got using the stock 7" wheel width and standard +38mm offset.....
From the centre of the wheel to the edge is 114mm (9" devided by 2)
From the back of the hub to the rear edge of the wheel is 95mm
Is that a -19mm Offset? If so i have 32mm more inner clearance and an extra 82mm of outside edge , pushing the wheels right out of the arches.
Or if thats a +19mm offset, i have 6mm less inside clearance and the wheels will extend a further 44mm ???
either way it'll look mean, but 82mm is A LOT of extra width!! Don't think these will fit a VX without a suspension lift!
