Results 1 to 2 of 2
Thread: Where is Fluid Fill on Transfer Case?
    Nov 2008
    1999, Astral Silver Metalic, VehiCross 0385
    Does the Tranfer Case Share Fluid with the Transmission?
    where is the Transfer case Fluid Fill Port?
    They USE the same fluid, but it's not shared.
    Look on the rear side of the transfer case, you'll see two plugs that are removed & replaced with a 3/8" drive ratchet...
    Top one, fill & check
    Bottom one, drain
  1. Replacing the fluid in transfer case?
    By Merrell90 in forum VX Troubleshooting...
    Last Post: 02/19/2016, 12:57 PM
  2. Transfer case #'s
    By simonsayz1 in forum VX Talk...
    Last Post: 01/29/2015, 01:01 PM
  3. 2WD transfer case?
    By So-CalVX in forum VX Talk...
    Last Post: 03/03/2008, 09:40 PM
  4. Transmission Fluid Filter Transfer Case Fluid Change
    By driver3 in forum VX Troubleshooting...
    Last Post: 09/16/2005, 03:23 PM
  5. Transfer Case
    By yal^ in forum VX Troubleshooting...
    Last Post: 04/16/2005, 10:12 PM
