Hey Ben !
I saw your request for help.
As well as you i'm on the market for new rims & tires.
I've done a lot of research for the past two months trying to find the right nice set for my VX.
So now on business;As i write this respond to you i'm looking at this well known web site : TIRERACK.COM there will find about 20 different kind of models/size that perfectly fit our VX with no lift required if you don't really want to.
There's few tires the mayority of the VX members use on their VX's for off roading i can name the nitto terra grappler,the nitto dune grappler & now the general grabber At2 which are all rated as A/T.
Of course there's many off road tires,but those are the most recommended tires by our fellow members because of they high off road performance.
Personally i've choose the american racing Jr cannon rimes which comes in two models,the all machined & the machined with black accent.
The size goes from 17x9" to 20x10.
If you want to save the lifting job then go for the 17x9;That size would be just ok for you.
Moto metal also carries a few nice rims for our VX that also match the silver finish of the astral & the kaiser along with the cladding.
Here is so much info about rims & tires that you cannot go wrong in any way choosing the right set.
For starters you can look at the thread named : POST OF ALL RIMS & TIRES OUT THERE, there's so many pics of VX's with aftermarket sets,lifted mods & complements that i assure you will help you out though.
I hope my input can be help full in any way
Dakar was just the begining.
