Results 1 to 5 of 5
Thread: Replacing Starter
    Nov 2007
    1999 Astral Silver
    Replacing Starter
    After searching, didnt see much on anyone R&R their starter.
    So I thought Id post up something with pics.
    First of all, most starters in any car may last about 80k or so.
    Theres an easy way to check to see if your starter is bad
    by bypassing the starter relay under the hood.
    Once you decide its bad, grab some tools and crawl under
    the Vx. Its necessary to drop part of the exhaust.
    So youll need to disconnect both rear flanges halfway
    back, and then the 3 bolts where the pipe on the dr side
    bolts to the manifold. Think youll need a few 14mm wrenches and
    a 17mm deep socket, long 18" roughly extension and think a
    12mm for the starter itself.
    Disconnect the + battery cable from the battery first.
    Unbolt the exhaust (see pics)
    then you can ubolt the starter and disconnect the battery cable
    and remove the starter towards the rear of the Vx.
    I got mine from BAP Auto, complete new starter and selenoid.
    Funny thing is, it didnt look like the one I took out, it was set
    up a bit different, but it did fit right into place and works fine.
    Must of been redesigned over the years, maybe a good thing.
    Once out, put your new one in and install the cable.
    When putting the exhaust back together, I suggest buying new
    bolts and gaskets from the dealer (total cost about $20)
    Once all bolted back, hit the key and your Vx is back on the rd.
    Total time takes about an hour to 2 tops depending on how rusty
    your bolts are. Mine being here in Az werent too bad.
    Check out our VX accessories @
    www.planetsvx.com
    click on the Vehicross button on the left side
    of the page
    Nov 2007
    1999 Astral Silver
    more info
    more pics to go by...
    Nov 2007
    1999 Astral Silver
    a few more
    pics of under the vx
    Nov 2007
    1999 Astral Silver
    last of them
    new starter part # I used from BAP for about $105
    and misc stuff you may want to pick up first.
    Apr 2007
    2001, Proton #1238
    Very cool! Thanks for the posting your progress.
  1. QUESTION: Engaging Starter from Starter Relay
    By Joe_Black in forum VX Troubleshooting...
    Last Post: 06/04/2015, 07:10 PM
  2. Starter dying?
    By volume311 in forum VX Troubleshooting...
    Last Post: 06/01/2014, 05:24 PM
  3. Starter Woes
    By iyafyl in forum VX Troubleshooting...
    Last Post: 04/25/2013, 06:51 AM
  4. Remote starter
    Last Post: 06/13/2007, 09:13 PM
  5. remote starter
    By james1_10018 in forum VX Troubleshooting...
    Last Post: 10/27/2004, 12:58 PM
