Results 1 to 5 of 5
Thread: How to set the Clock????
    1999, Ebony Black, VX, 1614
    This has to be an easy answer.
    How do you set the clock?
    Dec 2004
    It explains it in the manual if you have one.
    If I recall correctly, with the stereo OFF, you press the "recall" button on the left silmultaneously with the hour or minute button on the right to change the time. Keep the recall button pressed when you switch between hours and minutes.
    Or something like that. I think...
    Thanked: 7
    With the ignition in the ACC position, Press and hold down the button marked FM/AM (on the left of the radio under the volume knob). Now while holding that button down press the #1 preset button on the right of the radio. That's the hour button. Once the hour is set, press the #2 preset button the change the minutes.
    If you want to have the clock display while the radio or cd plays, press the FM/AM button then press and hold down the #4 preset button until it beeps (about 4-6 seconds). Normally the radio station or cd info shows all the time but now the clock will display after about 10 seconds.. To change back do the same procedure.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    I gotta look it up every time
    Working
    Got it set correctly.
    Thanks!
  1. reset your clock
    Last Post: 03/11/2008, 08:52 AM
  2. Clock
    By DeepSilentComplete in forum VX Talk...
    Last Post: 06/16/2007, 09:36 PM
  3. Clock
    By Mark B in forum VX Talk...
    Last Post: 10/23/2006, 11:07 AM
  4. Clock mod?
    By Doug in forum VX Talk...
    Last Post: 06/09/2005, 03:34 PM
  5. clock -- radio
    By billh23 in forum VX Troubleshooting...
    Last Post: 07/01/2003, 12:18 PM
