Page 5 of 5 FirstFirst 1 2 3 4 5
Results 61 to 71 of 71
Thread: CarSystem Refinish Restorer
  1. #61
    RR claims it does:
    RR Manual (see page #1 "Characteristics")
    Refinish Restorer is a natural oil based product that restores the original colour and shine to almost any plastic or varnished surface.
    Pics from rowhard's gallery:
  2. #62
    Jan 2011
    2001,proton yellow,0631
    thanks....
  3. #63
    Jun 2007
    2001, Proton
    Well here is a different opinion
    [QUOTE=vt_maverick;218199]RR claims it does:
    [Quote]Doesn't really darken the cladding (unfortunately) or cover up any discolorations but it sure makes it look brand new otherwise.[Quote]
    From VXKat post
    Carter Pewterschmidt
  4. #64
    I'm pretty sure Sue would tell you her cladding isn't a good benchmark. If that were the case, we'd have to conclude that it neither darkens nor adheres.
  5. #65
    [QUOTE=circmand;218205][QUOTE=vt_maverick;218199]RR claims it does:
    From VXKat post
    I "think" the difference in those two statements are due to:
    1) Rowhard had done more extensive and proper prep work on it, and it looks pretty "chalky" in the pic. After his prep, his is actually lighter than my "normal" color.
    2) Mine "seems" to be a lighter hue of gray to start with, ( oh my, we've beat this one to death haven't we gang?)....it darkened it a tad, just like anything "moist/oiled" appears a bit darker....just not by very much, IMO.
  6. #66
    99'/astral silver/vehicross
    My cladding was pretty faded and required contant Mother's BTB applications.
    I would say it restores your cladding to the same darkness as new. The key is going very little bits at a time and letting it "soak" into the cladding. It took me nearly 2 hours to put mine on I went so slowly and put two coats. The first coat I went around piece by piece with a saturated rag and really rubbed it in.
    I also washed mine VERY thoroughly before hand and took windex to some of the parts of cladding where I new that things like armor-all or eagle products had slung from my tires.
    I THINK the consensus about KATs (correct me if I'm wrong KAT) was that she either had some type of application before she owned it that was blocking the RR from penetrating the ABS very well or there was some type of residue she couldn't get completely off in her initial prep.
    KAT also had the unfortunate experience of being the first to find out that if it chips at all, power washing is a bad, bad thing.
    macintosh man
  7. #67
    Quote Originally Posted by technocoy View Post
    I agree techno.
    I'd let it go at least 3 months with zero products applied and no automatic car washes, then did a windex heavy duty wipe down a few times, a few hrs of 409 soaked paper towel stuck on the cladding by the filler door.....but even then, mine never seemed "chalky" or parched...just lighter bluish/gray in color...so maybe PO did apply something???
    Funny thing is, I'm having a heck of a time blasting it off some parts of my pass side (I overestimated that 95% off estimate in an earlier post...didn't realize there was still some there, not nearly as shiny as when applied)....so I do have some that's adhering really good.
  8. #68
    Jun 2007
    2001, Proton
    Just goes to show
    I agree techno.
    The better a product adheres to a surface the harder it is too remove it.
  9. #69
    I'll make a separate post about the lights too, but just wanted to keep this thread updated...
    It's been about a year and 3 months since I did the RR, and I washed her real good today since I had the time for once.
    Here's how she's still looking with NOTHING but washing.
    Sorry a few are really bright on the paint... I wanted to expose the cladding so you could really tell how dark it still is.
    My cladding was very faded when I originally put the RR on as well.
    There are a few places in back where it's started to fade just a LITTLE and a couple little bits here and there where rocks have hit, but it really looks no different than if it were naked and the same thing happened.
    I figure an a cooler day in the shade I'm going to try a "touch up" coat to see if it helps add to the coating. I'll post another update after that.
    This is good stuff as long as you get it applied right and/or your cladding isn't cursed like KATs! I could imagine easily going the rest of the year before needing to really touch it up. I haven't put any other product on it since I put the RR on.
  10. #70
    Dec 2006
    I applied one coat last year, and just did another coat recently. It looks great. I'm reluctant to do multiple coats at the same time, as I don't want it to build up and level off the cladding texture, or be more prone to chipping. I apply with a quality 2" paint brush in sections and buff nearly dry with a good microfiber towel 10-15 minutes later. This destroys both the brush and towel, as in the morning they'll both be hard. Best applied in, and left to fully dry overnight in a cooler garage. I've also used RR on the plastic bits of the factory roof rack and on corner pieces of the Thule 696 rack with equally impressive results.
    Bren Workman
    Gretna, NE
    (C) 402-312-1992
    I applied the R/R to my wing and it's still perfect. That's about 25 months ago.
  1. Replies: 10
    Last Post: 04/03/2015, 12:47 PM
  2. what removes tw trim restorer
    By sopo in forum VX Talk...
    Last Post: 09/14/2013, 07:44 PM
  3. Refinish Restorer, Mother's Headlight kit and 303 Protectant
    By technocoy in forum General Tips...
    Last Post: 08/29/2011, 08:50 PM
  4. cladding cleaner / restorer - anyone tried it?
    By ben-man in forum VX Modifications...
    Last Post: 06/26/2010, 10:48 PM
  5. Looking to refinish
    By Mile High VX in forum VX Talk...
    Last Post: 03/07/2010, 10:07 AM
