Results 1 to 10 of 10
Thread: 8 hours to replace window seals?
    Feb 2004
    01, Silver, 0603
    I got the metal window brackets so my windows actually go up and down. The rubber was pretty grrrd up, so I had to remove some of it for the windows to go all the way up. I want to replace all of the rubber around the window. The local body shop says I have to find the part myself and if I do get it I should expect 4 HOURS PER DOOR. That seems awfully long.
    Jan 2008
    1999 Astral Silver 0481
    Four hours each for non-high tech door mechanism is a lot of time;I mean if the doors were from a lexus,acura or bentley i may say ok,that sounds fair,but for our Vx doors that's a lot of time each one.
    Dakar was just the begining.
    i dont see how.. i remove my door panels in less than 10 minutes.. removing the window shouldnt take long.. unless maybe they are thinking taking the whole mechanism out with the window or something.. not sure but shouldnt take that long
    LOL...you're in Hawaii Brah...they're figuring in "Hawaiian time"...
    EVERYTHING takes twice as long in paradise...
    Feb 2004
    01, Silver, 0603
    I'm actually back in San Clemente. I could totally see a body shop in Hawaii telling me it would take 4 hours. I would then expect the work to take 4 weeks due to a mixture of "island time" and some problems with the mechanics "cousin". It would be worth it to still be there.
    Dec 2004
    Quote Originally Posted by ctp View Post
    That means they don't want to do the job, but will if you pay them 10x. Do it yourself - for free!
    Man, that's funny. Steps....
    Pull door cover
    Remove plastic insulator (don't tear!)
    Drop window
    Pull rubber seal
    Stand back and have a drink....
    Maybe a sammich, while you are at it....
    Slide in new rubber seal
    Raise window (up and down a couple of times checking seating)
    Tack plastic insulator back on
    Replace door cover
    The most time you spent on this job was having a drink and eating a sammich. Shops are hurting in these tough times so, can you blame them.
    Feb 2004
    01, Silver, 0603
    I was hoping for that kind of response. Where would be the best place to find the window seals? I also need to replace the plastic sheet. I'm guessing that's the insulator. What is it's purpose?
    Aug 2008
    Hmmm, a good place to start looking is from one of the "many" VX's that was totaled this past Winter.
    FWIW, you can make yourself a new insulator (vapor barrier) out of some 4 mil poly, (visqueen?) & duct tape.
    Look around with a search to find a contact number for Merlin @ St. Charles Isuzu, if you want new seals.
  1. Hours of quality entertainment!
    Last Post: 11/12/2010, 11:42 PM
  2. Replace seals when repack bearings?
    By LiquidVX in forum VX Talk...
    Last Post: 05/08/2010, 11:38 AM
  3. 8 hours in the garage yesterday...
    Last Post: 12/21/2007, 08:59 AM
  4. 4 hours and counting...........
    By 9tinyfingaz in forum VX Talk...
    Last Post: 06/10/2006, 08:24 AM
  5. Flight hours....
    By Francesco Rizzo in forum VX Talk...
    Last Post: 12/20/2004, 08:56 PM
