Results 1 to 15 of 18
Thread: Idle Issues
    Oct 2006
    1999 Silver VehiCross
    Idle Issues
    Still having issues with rough idle, sometimes dies after start up, and surging. P0171, P0171, and misfire cylinder 4 codes. Replaced throttle position sensor. I thought the plug on the left side of the throttle body was the map sensor but when I got home with the box it looked different. All the pics of the map sensor on the net look like what the gave me. Whats the plug on the left side of the throttle body and where is the map sensor located?
    If replacing these doesn't fix it I guess the fuel pressure regulator is next. I cleaned the maf but I guess I could replace that too. Just wanna get it fixed so I can get rid of it. I'm gonna loose my butt on this thing. Just wish I could keep the seats. lol
    Thanks,
    Mrcln1
    http://www.vehicross.info/forums/sho...threadid=14148
    look there for other fuel problems..
    2001,FOX FIRE RED MICA,0251
    Intake gasket leak
    Jul 2004
    1999/black/VX/black
    Intake gasket leak
    X2
    Dec 2004
    Quote Originally Posted by WILLY View Post
    Intake gasket leak
    x3 - a definite possibility!
    Cleaning the MAF may not help if it's just plain old fried. If you run an oiled filter (like a K&N) then the oil could have fouled it. Some people have had luck with cleaning when that happens, others have not.
    Good luck!
    Feb 2004
    '01 Ebony #0830
    Please try cleaning the Idle Control Solenoid first... If it's the culprit, it's an EASY fix!
    SilverBullet75
    Formerly: '01 Ebony VXSTLTH
    Now: '08 Saab 9-7x Aero 6.0L
    Oct 2006
    I run a regular paper filter. I tried spraying around the intake to see if the idle would speed up and it didn't. Wheres the map sensor located? I'll clean the idle control now.
    Thanks,
    Mrcln
    Feb 2004
    '01 Ebony #0830
    Here is the location. Please see the above link for further info. Hope it helps!
    Jun 2007
    2001, Proton
    now that is a good photo
    and clearly shows what you are looking for.
    just cleaned my idle control solonoid.. need a T20 torx screwdriver to remove it.. the screws on mine were pretty stuck.. best way to do it was to stand on the passenger side of the vx and put your weight behind the screwdriver to take them out.. cleaning was easy though, make sure to get that O ring too
    Oct 2006
    I sprayed the idle control with electrical cleaner yesterday when I thought it was the map sensor. lol I didn't try pushing it in or seeing if it moved when running. I'll do that tomorrow. So where is the map sensor located? Since I have one I might as well replace it.
    Thanks,
    Mrcln1
    Nov 2007
    1999 Astral Silver
    mine had the same thing for the last few months
    same exact code etc.
    Easy way to check.
    Start the car and while idling and the hood up, spray
    some carb cleaner where the lower intake bolts to the
    block/heads etc, by the Injector one at a time. If you hear
    the idle rise, then you have a vacuum leak, lean mixture.
    Problem, Lower intake manifold gasket.
    Its a phenolic material from the factory, really good idea on the
    surface, but when they break, you can drive a truck them them.
    Heres a pic of the gaskets, first normal good used gasket
    Check out our VX accessories @
    www.planetsvx.com
    click on the Vehicross button on the left side
    of the page
    Nov 2007
    1999 Astral Silver
    a good pic of the broken gasket
    btw, the replacment gasket kit uses quality paper style
    gaskets. The kit was only about $60 retail
    Labor, 2-3 hours
    broken gasket removed
    Nov 2007
    1999 Astral Silver
    and while it was apart, I took a pic of the intake off..
    chances are youll see lot of oil running thru the upper
    intake. Normal on these motors as we have found, but not
    the best thing.
    Put back together, the motor runs amazingly better as
    expected.
    Quote Originally Posted by Vehi-Cross-Az View Post
    Mine looks much like that right now, minus the S/C and the family of dead mice, heh.
    Did you get aftermarket gaskets? I got mine from ISUZUPARTS.com and they are more like a rubberized material with sheetmetal framework. Far from paper-like.
  1. VX Idle Issues
    By CatFish in forum General Tips...
    Last Post: 04/29/2017, 06:40 PM
  2. Fast idle, low idle, (stalling) temp gauge all over the place.
    Last Post: 11/07/2016, 08:48 PM
  3. VX Start-Up Idle Issues
    By VX-FAM1 in forum VX Talk...
    Last Post: 10/09/2015, 05:57 AM
  4. Idle issues. Low on Funds. Can only replace one now. Which one?
    By spitfire5454 in forum VX Troubleshooting...
    Last Post: 10/19/2012, 06:57 AM
  5. My idle issues.
    By VX-157 in forum Japanese Domestic Model (JDM) VXs
    Last Post: 09/17/2009, 05:35 PM
