Results 1 to 15 of 19
Thread: Oscillating Idle...
    Nov 2002
    2001, Foxfire Red Mica, 0260
    Oscillating Idle...
    encountered after placing shift in Park. Essentially, the idle fluctuates between 800 rpm (normal) and about 1500 rpm several times before settling at 800. At first, I thought I had my foot on the gas, but now I realize it's the car.
    Any thoughts as to why? Solution(s)?
    Thanks,
    Chris.
    Nov 2002
    Mine does this occassionally as well, just haven't got around to asking about it.
    May 2002
    2000, Proton Yellow, VX, 0584
    One semi-common problem could be the intake manifold gasket.. Those that have had that problem can answer to that..
    Scott / moncha.com
    Apr 2003
    2001, Ebony, 0761
    Mine just started that too.
    Oct 2002
    2000 Ironman #654
    Happens to me too, just every once in a while, maybe once in a couple of months. It's been like that for years with no ill effects.
    1999, ASTRAL
    Lightbulb Only on Hot Humid days...
    Mine does this when the temperature outside is above 85 and the humidity is over 80%. I think the VX is choking on smog like the rest of us. Issue goes away when the temerature and humidity drops below those levels. I doubt if it's anything serious, it does go away.
    NAVIGATOR
    Nov 2002
    LOL! That's like 95% percent of the normal weather here!
    1999, ASTRAL
    Talking I Vacation in Orlando...
    I love it there, but man is it ever like a sauna July 4th weekend I am there like clockwork, does it get much hotter than that? Anyways, that issue only arises on bad air days here in MD, I think you guys have better air quality there, but definately more heat and humidity LOL
    Nov 2002
    Jul 4th? Hot? Nah, we're just coming out of Spring at that point. Come down, say, around early September. That'll charge your batteries! As a Florida native, my sinuses freak out if the relative humidity drops consistently below something like 60%. Trips out West always take weird "climatizing" turns! LOL! Don't even get me started on cold! I've spent too many Christmas visits to Alexandria and Thanksgivings to NYC for that! No no no... sun sea and sand for me please!
    2000,black,029
    Could also be a dirty idle air control valve. If it gets gummed up with carbon then it can't react fast enough and may overshoot and undershoot. Simply remove the valve from the throttle body and clean with carb cleaner. Also clean the air passage in the throttle body. Could be the intake gasket as well. See my post on how to check for a leaking gasket. just use some carb cleaner and spray around the intake. If there is a leak you should hear a change in rpm.
    Andy from Isuzu America
    Apr 2003
    01, silver
    Mine did it first at less than 1000 miles. So I'd dount if it is dirt.
    Nov 2002
    Thanks all..
    I'll follow advice and keep you posted.
    Nov 2002
    Yeah, mine's done it since it had 16 miles on it. I've had the same thing happen with my '95 Trooper Limited with the 3.2L DOHC. Changed the PCV with next tune-up and checked all seals with nothing showing up. So when it happened on the VX I poked around and couldn't find anything obvious either.
    May 2003
    Lightbulb
    Just a thought....are all you guys experiencing this with the air conditioning "on"....just wondering if the load on the engine of cycling the compressor could be affecting your idle....
    I also know that on some cars the air conditioner compressor has an idle control module....don't know if the VX has one...but just a thought....
    Honestly don't run my air conditioning much at all but the few times that I did I thought I noticed my idle speed vary along with compressor "load" which I took as normal.
    Hope this gives you something to go on!
    '99 Astral #1977
    Good point. I noticed the same.
    RichD
  1. VX Idle Issues
    By CatFish in forum General Tips...
    Last Post: 04/29/2017, 07:40 PM
  2. Fast idle, low idle, (stalling) temp gauge all over the place.
    Last Post: 11/07/2016, 09:48 PM
  3. My idle issues.
    By VX-157 in forum Japanese Domestic Model (JDM) VXs
    Last Post: 09/17/2009, 06:35 PM
  4. Fails to Idle
    By newthings in forum VX Troubleshooting...
    Last Post: 10/12/2005, 10:43 PM
  5. idle
    By cascabel3 in forum VX Troubleshooting...
    Last Post: 12/17/2004, 09:30 AM
