Heck, I would drop the $$ for C/F cladding. Just to shave the weight. But ya, the issue is getting enough interest cause those molds would be pretty insane and not worth the time without enough inventory interest.
I would still be down for a C/F insert (another one), but I am probably in the minority since I want extraction, not induction.
I'll dig around the net and see if I can find the article, I'm pretty sure he had the temp measured at a dyno shop to verify the results.
I will say that it's far more likely that a vented hood would make a big difference on a G35 than on a VX, as the distance between the top of the engine and hood is like 1" or less, as opposed to where we probably have at least 3-4 inches. To put that in perspective, adding an Eaton style top-mount SC to a G35 requires you to cut the hood open or buy a "bubbled" hood to make it work, whereas we don't have to do anything of the sort to make the Alpine system fit. Guys that do this cooling business take the engine cover off, remove the heat wrap from the bottom of the hood, replace the hood with full CF, and then add 6-8 vents. It doesn't make a ton of difference sitting still, but supposedly it does wonders for removing heat when moving because the vacuum created between the intake and the vents pulls the heat out.
