Results 1 to 9 of 9
Thread: Torsion Bar
    May 2009
    2001 PROTON 0792
    Torsion Bar
    I have been told that the torsion bar can be adjusted to raise the front ent one inch. Since the VX appears to sit up in the back I'd like to do this. My mechanic said this will mess up the alignment causing tires to wear. Has anyone done this and did you have any problems.
    2001, Dragon Green, 1342
    Quote Originally Posted by DougieVX View Post
    most of us have had to do it with suspension mod,s, different size tires, what have you. Yes, it will change your alignment, thats why alignment's are adjustable. Maybe think about getting a different mechanic while your at it.
    May 2009
    2001 PROTON 0792
    I guess my mechanic has never seen a VX before. I want to raise it a bit and have considered a lift kit but really don't want to spend the money. I have some 15X8.5 aluminum rims that I like. I don't really like the stock 18" wheels. TOO CHROMEY!!!
    Well, if he ever worked on a old VW, he would know about torsion bars. Anyway, you can do it yourself, just follow the bar back and you will see the adjuster. Wire brush all the crud off, give it a good soaking with liquid wrench, or blaster, or your perfered lub, (wd40 will evaporate) the day before, measure the gap you have between front tire and cladding, both sides, mark the adjuster bolt to keep count and go for it, then take it in for an alignment
    May 2009
    2001 PROTON 0792
    I'm not much of a mechanic. I don't think I'd feel comfortable adjusting the torsion bar.
    then take it to a alignment shop, tell them what you want and have then do it and your alignment too
    Jun 2008
    2001,black, vehicross 1353
    dougie.do you have a rachet and a 27mm socket and a can of wd 40, a jack and a tape measure? Thats all you need. Use the search feature as this subject has been covered many times, and there are pics too.
    Milwaukee WI
    May 2009
    2001 PROTON 0792
    Quote Originally Posted by djvx View Post
    I have everything I need to do this. Maybe I'll give it a try next warm dry day. I'm new to this site and have so many questions. I really appreciate all the help.
    2001, Ebony Black, 1153
  1. torsion bar
    By last ride in forum VX Troubleshooting...
    Last Post: 10/06/2012, 07:22 AM
  2. HD Torsion Bars: Anyone tried them?
    Last Post: 02/01/2012, 09:14 AM
  3. Rear torsion bar....
    By raver_boi_88 in forum VX Troubleshooting...
    Last Post: 09/07/2011, 03:47 PM
  4. Torsion bar
    By texasvx in forum VX Troubleshooting...
    Last Post: 09/28/2006, 05:18 PM
  5. Torsion bar adjustment
    By sarge202us2003 in forum VX Troubleshooting...
    Last Post: 03/01/2006, 09:29 PM
