Results 1 to 8 of 8
Thread: Fan Clutch
    '01 Ironman
    Fan Clutch
    My fan clutch is out, revs real high to the point it sounds like I'm in a windtunnel when I reach 3,500 rpms, loss of power, and a little shake. I am trying to remove the 4 nuts attaching the fan but the pulley turns as I try to wrench on it. I had a friend try to hold the belt tight but that didn't work.
    Any inventive ideas for isolating the pully that attaches the fan clutch? I think I just need a LONG pry bar to get in there between the studs (possibly long enough to hit the ground?). Wedge pry bar between 2 of the studs with nuts and center of fan clutch assembly, and then place one end of the pry bar on the ground. I'm guessing thats how ya do it, just crack them loose one at a time using the pry bar to isolate, leave the nuts on there so I don't strip the threads on the studs.
    Am I on the right track, or is there a better way?
    i left the belt on, and used a 10mm (i think) box end wrench with a small pipe on the end of it, then used a rubber mallet to hit the end of it, that basically replicates an impact wrench
    '99
    Be sure to read this before putting it back on-
    Mark
    01, LineX tan/black, 1055
    I used a large box end and wedged it in the fan to minimize rotation, then I hit the 10mm wrench with a mallet, same concept, it was a PITA, and resulted in a little bleeding from rubbing against the radiator.
    I didn't do the balancing thing, nor did mine look like the mount in the picture? No problems, mine sounds like a semi now, and no cooling problems.
    Have fun...
    hmm mine wobbles like theres no tomorrow it doesnt make any noise or anything though so i figured it was just a fan blade being a bit bent since i took it from a wrecked vx.. maybe its not balanced properly, ill have to look into that today.. class was canceled
    1999, Ebony Black, 1856
    '01 Ironman
    Alright I figured out how to isolate it, just needed a better/thicker pry bar than the screw driver I had at the time. Didn't see any marks on my new to me/used fan when I was installing it, the entire mounting area was blue But everything seems to be working fine, no longer sounds like a semi and fan is spinning a LOT more freely than it was.
    Thanks for the responses but I felt like a moron for asking once I saw how easy it was with a larger 1'-6" SQUARE prybar. :embarrass Just stick it under one of the mounting bolts and wedge against the center of fan then crack one at a time and once they were cracked they were easily taken off.
    '01 Ironman
    I am guessing yours is starting to go out then, I saw mine had some movement so I got a new one from a local junkyard was too lazy to install since it seemed to be working fine, then 3 months later (2 days ago) it started sounding like a semi in the upper rpm range. The new fan is tight with no wobble at all, and after I put the fan shroud back on the semi/windtunnel noise is definately gone.
  1. Fan and clutch
    By VehiTONY in forum VX Troubleshooting...
    Last Post: 07/01/2014, 05:21 PM
  2. How to test a fan clutch?
    Last Post: 04/18/2013, 08:33 AM
  3. fan clutch oddity......
    Last Post: 07/10/2011, 09:24 AM
  4. Repairing The AC Clutch
    By crotchrocket in forum VX Troubleshooting...
    Last Post: 08/10/2009, 12:35 AM
  5. Bad Fan clutch or....?
    By TJMaxx in forum VX Troubleshooting...
    Last Post: 03/21/2007, 09:52 PM
