Results 1 to 15 of 30
Thread: trimming cladding
    May 2009
    2001 PROTON 0792
    trimming cladding
    I have read that several members have trimmed the cladding on the front to help with larger tires. The thought of cutting the cladding doesn't make me feel well but I gotta get bigger tires....if nothing else, for a more stocky look. Can someone tell me where the cladding is actually cut. Is it visible when looking at the vehicle. And as thick as the cladding is what was used to cut it.
    mmmmmm-hmmmmm...
    That pic isn't mine, but is of the R-F wheel well.
    May 2009
    2001 PROTON 0792
    I work so much better with pictures. That don't look too bad. I wonder what tool would cut through that without cutting my arm off.
    Available at Harbor Freight...
    2000, Ebony, VX, 0370
    Thanked: 12
    Dougie, depending on how big you go with your tires, and if you lift or not, you may end up cutting off even less of the cladding than is shown in the picture. When I was stock height and installed the Terra Grappler 285/60/18's I had to trim off just a tiny corner of the cladding, and that corner was just the tip of the cladding that sticks into the front of the wheel well. I didn't have to cut anywhere near the exterior lip of the cladding so unless I'm parked right next to an unaltered VX AND you stick your head into the wheel well and look at the front corner of the wheel well you would never know anything was removed. I ended up using a Dremel tool with a cut-off wheel to trim the cladding then used some sand paper to smooth everything out for a factory look.
    May 2009
    2001 PROTON 0792
    That picture Ldub sent looked like it would work but I didn't see the electrical cord. I think I got it not. I read where guys were cutting cladding and beating sheet metel so I got worried.
    Thanked: 12
    You shouldn't have to do any serious trimming or sheet metal bashing until you get into some of the larger tire sizes (like Ldub's massive set up).
    (Ldub's massive set up).
    ...who told YOU?...
    Jan 2008
    1999 Astral Silver 0481
    LDUB are you serious ? This is nuts
    Man you make me laugh so much I was close to piss my self hahahahaha
    That machete looks like the ones my grandpa used to open the coconuts at the beach to make some tasty pina colada
    I can just imagine dougie with this machete trimming the cladding
    Dakar was just the begining.
    If you go on the Harbor Freight website, & find that particular instrument of certain destruction, you'll find that it's a Japan saw, which makes a straight, relatively smooth, cut.
    They cut on the "pull" stroke, so they take a little getting used to...
    Although I can definitely see the humor in trimming the cladding with a machete......
    Jan 2008
    I think dougie will have problem handling this saw since he's not japanese at all jejeje
    01, LineX tan/black, 1055
    I didn't trim the front of my cladding at all, but rather behind the wheel. I used a craftsman razor blade pocket knife. You could probably use a pocket knife. I then took a 3lb sledge and banged in the body seams that were still in the way, I had to use an cutting wheel to modify my sliders as well. No problem...I had never done this either so don't worry, it can be done. Now I am making skid plates and soon starting a bumper. It is very addictive. From this:
    To this:
    I trimmed just a tad off of my cladding
    A sawzall did the job like a hot knife cutting butter!
    However when I had previously did some minor trimming for tire clearing a razor knife worked just fine.
    May 2002
    2000, Proton Yellow, VX, 0584
    I held out for so long, when I got my Nitto TG's (285-60-18) I could bear it. Then I actually did it. It's very easy with a razor knife and you don't take very much off. Don't let some of these guys scare ya, they're harmless. Unless you're a VX
    Scott / moncha.com
    I had to trim mine as well. Its not hard and it does not detract from the external look of the VX (unless you do a major job like Billy (Triathlete) did .
    I used a Dremel with a small cutoff wheel attachment to trim mine. It's quite simple. I can't imagine getting enough leverage with a hand tool to do it, unless you remove the front bumper cladding. I did mine in the parking lot of the the tire shop.
  1. Clad Trimming Revisited
    By Maddawg in forum VX Talk...
    Last Post: 09/30/2012, 06:35 PM
  2. Cladding: Trimming and BFH question
    By c09<[865P in forum VX Modifications...
    Last Post: 08/29/2010, 07:06 PM
  3. Trimming the front cladding
    By MSHardeman in forum VX Troubleshooting...
    Last Post: 03/24/2006, 11:11 AM
  4. Will these fit my 01 18's with NO trimming?
    Last Post: 05/12/2005, 06:24 PM
  5. Trimming the body Cladding
    By dubsracer in forum VX Talk...
    Last Post: 08/19/2003, 02:50 PM
