Results 16 to 30 of 39
Thread: Body Lift?
  1. #16
    I found the thread I was thinking about: http://www.vehicross.info/forums/sho...eferrerid=1999
    He said a few times he would post pics of his lift but never did and has since sold his VX. Maybe search for the VIN to see who bought it?
  2. #17
    you can also use hockey pucks to do the lift. cheap effective way.
  3. #18
    i actually kinda casually spoke with some local offroad shops about doing a body lift on mine because i want 35's....really bad lol....(i know, dumb kids)
    he said the biggest issue would be to extend the shift linkages and the steering components and longer brake lines...
    if you could fab up longer steering components and shift linkages you would be A-OK
    Nov 2003
    1999,Victory White, Ironman, #0414
    Wrench 3" body lift info
    A member of this board back in '04 got a local company to work with Independant 4X4 to modify a Trooper body lift for his Ebony...all the things mentioned earlier were issues...body mounts, linkages, gas tank mount, etc.
    Here's an old link to the thread discussing it:
    http://www.vehicross.info/forums/showthread.php?t=1194
    And an link to his old web page with some pics:
    http://www.boarzhead.freewebspace.com/photo3.html
    Looks good...minus the severe need for tires/wheels
    :bwgr:
    Dreamers of the day are dangerous people, for they
    dream their dreams with open eyes, and make them come true.
  5. #20
    Talking Say What?
    So, what'sat make me?...
    The dumb ol' man?
    And Ryan? (LittleBeast)
    The dumb slightly older man?
    We've both got our sites set at 35 too......
  6. #21
    guess its sort of a race then huh??
    i may lose though, i have my sights on paying back greg (for my skid plates that he made and hand delivered to moab for me) and then some body armor and a front locker before a body lift
  7. #22
    2000 IronMan #11
    ezem1y is who I was talking about. He ended up just putting a tropper body lift on it.
  8. #23
    So what exactly is the point of a body lift and a suspension lift together? A suspension lift will give you more underbelly clearance and a little more room for bigger meat. A body lift will give you more tire clearance and save the CV angles, but together is it simply to get more clearance for bigger tires? Is that the only "benefit"?
    you've got it, good sir...
    body lift is purely to fit bigger tires..
    if someone could manufacture a good body lift, we could easy roll 35's with no CV issues...(interesting idea eh? )
  10. #25
    Right, but this would simply be for looks, right? I mean, with 35"s you would get some more clearance underneath, but you would get more clearance from a suspension lift, right???
    the combination of a suspension lift with body lift, allows you to get maximum clearance underneath (suspension lift) and then the best approach and departure angle possible, (body lift) along with the ability to get over bigger rocks, cracks and holes with larger tires (combination)
  12. #27
    97 Jap Import, Black BEAST
    As we have independant front axles the suspension lift does give greater ground clearance on the front. Most 4x4's that have a solid front and rear axle do a lift to get bigger tyres as the only way to get better ground clearance on a solid axle truck is to fit bigger tyres.
  13. #28
    That' why I've always been "on the fence" with regard to differential drop brackets...
    You lose 40 - 50% of the ground clearance that you gained by lifting...
  14. #29
    I agree, I have wound my front right up but i will be putting locking wheel hubs on so 90% of the time there will be no wear to the cv joints or boots. Winding the front up and dropping the diff to cope is definately an aesthetic thing and not an off roading mod
  15. #30
    "i will be putting locking wheel hubs on so 90% of the time there will be no wear to the cv joints or boots."
    Fine for our JDM bretheren but not really an option for ours (unless someone perfects the TOD switch).
  1. Indy4x 3" body lift kit 4sale
    By jmayer40 in forum Archives
    Last Post: 09/28/2016, 07:12 PM
  2. Body Lift Guys
    Last Post: 05/08/2015, 04:15 PM
  3. body lift or not???
    Last Post: 05/15/2012, 03:14 PM
  4. Lift thread to end all lift threads
    By tbigity in forum VX Modifications...
    Last Post: 05/22/2007, 10:54 PM
  5. Rear bumper & body lift
    By ezem1y in forum VX Modifications...
    Last Post: 08/23/2005, 12:40 AM
