Results 1 to 7 of 7
Thread: Error Codes
    Error Codes
    Hi guys...
    I've just bought a ScanGauge 2 (thanks CrotchRocket!) and I have a couple of error codes! They are 1392 and 1393. According the the list on here they mean G voltage High and G voltage Low. Can anyone translate and possibly tell me if I should be worried?
    Thanks
    Nick
    Bump!
    No one?!?
    What does the "G" stand for?
    Never heard of that code...
    Oct 2008
    UK Sunburst Ltd 000/175
    Hiya,
    I think the "G" stands for "Gravity". I believe there is a gravity rollover sensor (as Isuzu call it). I think it's there to cut fuel if the VX turns over. Perhaps someone can confirm my suspicions. There again I could be completely wrong. Try goggling it
    Kirk
    Oct 2008
    scarlet kipper
    I've looked further into these codes (P1392/93). I suspect my last post was a scarlet kipper. Jag and Ford and poss others indicate that it is something to do with the ECM/VVT and the glow plugs or Gap (which doesn't make sense when talking about the VX). Have you tried clearing the codes with the SG2 and then do the codes return?
    Kirk
    PS I also found this on the web.....
    "I have a 1997 isuzu trooper automatic .6 cyl. and i have been trying to get it inspected for months now and it comes up with the code p1392 "random misfire"the first mechanic told me to go change my spark plugs so i did then i took it to someone elts they said change fuil fillter i did,then still didt clear it up so the said coil packs so i changes 3 of them that looked a little rugged then they said change my mapping sensor so i did that aswell..i called isuzu dealer
    3 hours away said they couldt help me .no one can figure out what it meens it comes up as a g senser but mine not being a deisel so it doest have a glow plug or a gsencer they said..so im lost ..please help this woman is seariouse distress.."
    Answer
    "Hello,You may have an o2 sensor that is causing a problem.The sensors function is to read exhaust gases before convertor so the computer can run injection system rich or lean.If it runs a little rich it can misfire one or more plugs and wont pass emissions test.Thanks for your question.Roger"
    Cheers Kirk
    Yes I did clear them but they came straight back.
    Nick
    Mar 2005
    01 Ebony - #0379
    The G Sensor is located under the center arm rest behind the E-brake between the seat backs.
    Check your connections.
    G-Sensor
    The G-sensor installed inside the center console detects the vehicle deceleration speed and sends a signal to the EHCU. In 4WD operation, all four wheels may be decelerated in almost the same phase, since all wheels are connected mechanically.
    This tendency is noticeable particularly on roads with low friction coefficient, and the ABS control is adversely affected.
    The G-sensor judges whether the friction coefficient of road surface is low or high, and changes the EHCU’s operating system to ensure ABS control.
  1. Error Code 507
    By RodL in forum VX Troubleshooting...
    Last Post: 12/19/2013, 05:38 PM
  2. upload error
    By lenny in forum VX Modifications...
    Last Post: 01/30/2004, 10:28 AM
  3. Over spray error ( How to remove )????
    By loco6464 in forum VX Talk...
    Last Post: 11/09/2003, 04:21 PM
  4. CD Error Codes
    By MegaSpent in forum VX Troubleshooting...
    Last Post: 07/14/2003, 09:08 PM
  5. Help With My Own Net Error?
    By BaM*BaM in forum VX Talk...
    Last Post: 06/21/2002, 05:36 PM
