Results 1 to 9 of 9
Thread: Rear speaker mounting depth?
    Just wondering what the max mounting depth is for rear speakers in the stock location? WWill be replacing with 5 1/4 or 6 1/2 seperates since I have a rattling blown rear pass. side speaker.
    If you don't get any response then PM etlsport. I know he's replaced his.
    Reading through several posts some say you need shallow depth, some say no, some say nothing. Just want some idea before I order something.
    i went with shallow mount 6.5s
    in the first pic you can just make out the back of the magnet behind the bracket, it is probably within 1/2" of the tire well on the bottom
    2001,FOX FIRE RED MICA,0251
    I wouldn't even mess with them cause those rear panels are a mo fo to put back on OMFG, there are much easier ways to get good audio without those 2 rear speakers,new kicker 3 ways for the doors and kicker tweeters where the tweeters go and subs in the back is what I did and mine sounds awesome.
    billy- 2.25
    referenced through best buy's information site
    referenced through metraonline.com
    referenced through the12volt.com
    Quote Originally Posted by WILLY View Post
    Or surface mounted (box) speakers on the "b" pillars.
    Jack & I have both done this.
    2001, Ebony Black, 1153
    Once you get into it, it is not that bad, just takes a day to take your time and do it right. The speakers I used were exactly the max mounting depth once you modify the brackets to fit the 6.5" because my speakers are about 1mm from touching the metal on the backside Here is my build thread:
    http://www.vehicross.info/forums/sho...peaker+install
    Has anyone heard the Hifonics Zeus line of speakers? In particular I am looking at the ZXi5.2's for both the door and rears. I know back in the day Hifonics put out some high end amps but I don't know a lot about their current crop.
  1. Need Rear Speaker Writeup
    By ipd in forum VX Modifications...
    Last Post: 08/31/2016, 12:07 PM
  2. Rear seat mounting bolts whoopsie
    By SuperBoomTurbo in forum VX Talk...
    Last Post: 10/22/2012, 08:37 AM
  3. Rear speaker access
    By crager34 in forum VX Modifications...
    Last Post: 02/21/2005, 01:19 PM
  4. Rear view mirror mounting
    By skullcap in forum VX Troubleshooting...
    Last Post: 08/30/2003, 09:10 PM
  5. Rear View Camera mounting
    Last Post: 04/28/2003, 07:31 AM
