Results 1 to 4 of 4
Thread: Help installing sway bar bushings
    Nov 2008
    1999,Astral Silver,VX,1238
    Wrench Help installing sway bar bushings
    Is this a 2 man job??? For the life of me I can not get the metal brackets that came with the Energy suspension sway bar bushings to fit. It seems as if they are about 1/2" too long and keep getting hung up when I try to install them. I have instructions from a previous thread printed out and it appears to be an easy job.
    I have no problem un installing/re installing the stock ones. I feel like I need a third hand to pull my front skid plate down, Pull on the sway bar, and install the bracket all at the same time!
    BTW I have the 9.5163G 28mm Bushings.
    Thanks
    Wrench Hope this helps...
    Check post # 48 in this thread......
    http://www.vehicross.info/forums/sho...threadid=15461
    Nov 2008
    Thanks Dub. I missed that one!
    2001, Dragon Green, 1342
    Quote Originally Posted by PittVXr View Post
    didn't bother reading the thread the dub posted, but just know when I installed mine, they were a PITA, had to undue the front plate, and what have you
  1. Sway Bar Bushings
    By JAMAS in forum VX Talk...
    Last Post: 05/28/2009, 12:00 PM
  2. Front Sway Bar Clamps and Bushings
    Last Post: 12/08/2008, 11:45 AM
  3. Polyurathane Sway Bar Bushings
    By CrzyFool in forum VX Modifications...
    Last Post: 10/22/2005, 06:45 PM
  4. Sway Bar bushings
    Last Post: 08/28/2005, 07:13 PM
  5. Help installing sway bar bushing
    By chucklee in forum VX Troubleshooting...
    Last Post: 08/04/2003, 08:36 AM
