OK, I've been doing a bit of work on my VX and suddenly, my battery doesn't seem to be holding a charge - since yesterday it's been having trouble starting, and this morning I needed to jump start it. The only thing I've done with the wiring is replace the battery terminals, and the connection seems fairly secure (and I jumped it with the cables clamped to the terminals and it fired right up). I had the radio on for a little while the other day, but it didn't have any trouble starting up immediately afterwards. I believe I replaced the battery about two years ago. Is this a normal lifespan for a battery? Is it just coincidence that it died after I installed the new terminals?
 .  I changed the terminals because I'm working on a high-end audio install and needed to upgrade them to accomodate a 1/0 ga power wire.  I haven't installed any additional wires yet though - just the 4 and 8 ga factory installed wires.
