Results 1 to 15 of 17
Thread: Pulled off my badges, but...
    2000/Proton/0651
    How should i get rid of my "ghost" marks?
    Time is about the only cure - you could try some light compound but be careful. Ghost logos can cost hundreds of dollars - I think they look cool and most people won’t even notice it unless you point it out.
    May 2002
    2000, Proton Yellow, VX, 0584
    Did the paint fade making the "ghosts" or is it the oxidation of the clear coat.. You can try using a clay bar to rid the paint of the oxidation around the letters..
    Scott / moncha.com
    2000/Proton/0651
    Wow,
    you're quick! I'm not too smart, what do you mean "light compound"?
    Don't know if it was fade or the paint. A friend noticed it right away and said to buff it out. Is that good idea?
    May 2002
    If you buff, just be careful. The clear coat is very thin and can damage quite easily. I'd do some of the other tips first and if to no avail, go to a pro and see what they think.. Some stuff is best not left to DIY...
    '99 Astral #1977
    I used Scratch Out scratch and haze remover by KIT. It is safe for clear coat and removes paint and scratches from door dings as well as swirl marks from car washes and slight oxidation. Got rid of my ghost images and marks from working off the badges and glue from the finish.
    2000/Proton/0651
    Hey Rich,
    thanks! Went to Pep Boys this weekend and looked for it. Didn't find it but found Meguires "Scratch X" (same stuff most likely) and it worked great! Would really recomend it to anyone. Can't see anything (Unless you look really, really hard).
    alan
    Aug 2005
    Black, 1997 JDM
    Is this ghost effect on just the clear top coat of the paint finish or has it penetrated into the actual paint color? I was thinking of just having the clear top coat sanded off and re-coated.
    May 2002
    Chances are, it is affecting the acutal color coat (If it's faded) If it's just a scratching problem, you can use a scratch remover.
    2001 Silver 0954
    I kinda like the ghost look of ISUZU on mine. If someone looks at it at just the right angle, they are rewarded with the hidden answer that they are looking to find. I am guessing that it would probably be tough to intentionally duplicate ghost writing.
    Dean
    2001 VX
    St. Louis, MO
    Aug 2005
    Black, 1997 JDM
    Quote Originally Posted by Moncha
    It could be that this ghost effect is actually the original color that has'nt been faded because of the decal covering it from UV exposure. If so, you maybe correct to assume that the actual color of the car has faded and not just the clear top coat. Thanks for the input.
    It would be the basecoat (color) that faded. Clear rarely fades, it just cracks and flakes mostly. If it were anything to do with the clear, a goof wetsand and buff usually takes care of that.
    What you can do is have the entire VX wetsanded down to the basecoat and then have a clear zapped over it. Its really not the funnest job for a paint shop, but painting after a wetsand (not grit sand) is clearly the best way to go if you want a great finish.
    Yes, it costs a few bucks.
    Aug 2005
    Black, 1997 JDM
    Thanks for your advice. I'll let them run an estimate on the job and see how it goes from there.
    I have a question for you all.
    I recently tried to debadge the rear hatch "ISUZU" and have come across a problem in which when i took off the crome lettering the sticky part stayed behind. I spent about 20 minutes trying to get the sticky "I" off and finally gave up and came here for answers. Any help or solution? thanks,
    greg
    '99 Vehicross - Daily Driver
    '93 Wrangler - Tank in Progress
    2001 Silver 0954
    Goo-Gone worked well for me.
    Dean
    2001 Vx
    St. Louis, MO
  1. Badges...and if so, which ones?
    By ipd in forum VX Modifications...
    Last Post: 12/09/2016, 01:40 PM
  2. Pulled the trigger on an H3
    By BigMeatVX in forum Chit-Chat ...
    Last Post: 06/10/2010, 12:36 PM
  3. Pulled over for questioning
    By Scott Harness in forum Chit-Chat ...
    Last Post: 02/22/2010, 03:17 PM
  4. cop pulled me over
    By Pepino in forum VX Talk...
    Last Post: 02/21/2008, 01:14 PM
  5. Cop Pulled Me Over Today!
    Last Post: 09/13/2005, 10:58 AM
