I keep getting err 3 code. says i need to eject cd. but it won't eject. is there any simple way to fix or get the cd's out. or is it just as simple as, get a new sterio. thanks for any help. Satch
yep
If you want to get serious and have 750.00 to spend, this might be a good deal. Look at part II, the Alpine system. http://www.vehicross.info/forums/showthread.php?t=16046
The other solution is:
On a serious note-- Try disconnecting the battery for at least an "hour", and then re-connect and try it again.
Look here...
http://www.vehicross.info/forums/sho...light=CD+eject
Found that, & tons of other interesting reading material when I searched "CD eject".
I like your method tho of 'suggesting' search criteria. Just telling someone to use the search function without any help is kinda like telling someone to whip up a batch of chocolate monkees without telling them what's in it.
Case in point would be to search on CV boot to try to find the contact info for Independent4X. You'll be reading for hours unless you search on MechaTech instead.
Dub Da Man.
Usually when this kind of situations happens you ended up opening the changer to get the CD out.
This happens when the changer's synch system get meesed up,mostly because of a broken gear or one of the rubber belts worn to the point it is slacky or even burst
Dakar was just the begining.
I hate to say it, but Riff Raff is sort of right. Give the player a good tap and power it up again. It *might* work. It worked for me, at least.
Once the CD is ejected, eject the rest of the player. Start looking, now, for a cubby hole to replace it.
Originally Posted by Wiki
1> Bang on side while pressing eject and Cd slot buttons.
2> Alternatively turn ignition on and off while doing #1
3> Remove player from holder, turn it upside down.. still connected to power bang a bit and press eject numerous times.
These are the ways I was able to conquer the err 3 on my player.
Anita
2000 Ebony #263
AnitaProtich.com
No, still have my original. Long story but the last time it happened where I really thought the thing was dead was when I turned the player upside down and pressed the eject. Out popped the CD.
Mind you, I banged on the thing on every side without luck until I turned it over and pressed the button.
The player works fine now.
thanks for all the tips, i will try them all. it worked for awhile the other day and then when south again. will let you all know what worked. thanks again.
satch
