Results 1 to 6 of 6
Thread: Engine Idle Issue - TRIED EVERYTHING!
    Oct 2007
    2000 Victory White Ironman
    Ok the ZuZu idles at 2k and will rev between 2k and 3k. Replaced TPS, FPR, IAC and intake gasket. There is no check engine light nor any codes. WTF?!?!
    Please any ideas?
    2001, Ebony Black, 1153
    bad gas? water in tank? fuel lines clog? fuel filter shot to heck? fouled spark plugs?
    Remove the two bolts holding the EGR. Note if loose. Inspect for soot blowby on the gasket. Apply high temp copper coat on both sides of gasket (IF not broken) and retighten.
    Cracked vacuum hose at connection.
    Roy
    Mar 2006
    Did you cleaned your throttle when replaced IAC? And I'd say to check MAF performance.
    1987 AMC Eagle: stock
    Oct 2007
    LittleBeast - that was one of 2 things the autoshop could tell me, it does not appear to be a fuel problem.
    NewThings - that was the other thing they said - no vacuum leak detected.
    Uncle_Asa - Yes, cleaned the throttle and the IAC and had replaced MAF. (Forgot to list that as one of the things replaced.)
    An interesting update - We "manually" adjusted the IAC sensor and through trial and error, got it to idle at the proper idle speed in both park and drive. No check engine light either. I'm wondering why we had to adjust the sensor manually for it to work properly. Possibly the plug that the sensor plugs into is bad?
    Sep 2008
    1999 White IronMan
    Check this thread I just started...
    http://www.vehicross.info/forums/showthread.php?t=16136
    It could be that diaphragm that I (in a round about way) replaced... I had same symptoms you describe...
    We sit together, my VX and I, until only the VX remains.
    --Iamironman
  1. Idle rev issue- No solution yet...
    By jasonm621 in forum VX Troubleshooting...
    Last Post: 07/03/2012, 08:19 AM
  2. Engine Idle and Stalling Problem
    By ALC1717 in forum VX Troubleshooting...
    Last Post: 02/29/2012, 07:52 PM
  3. Another Idle issue
    By housertl in forum VX Troubleshooting...
    Last Post: 09/27/2011, 06:29 PM
  4. 01 Engine Issue????
    By skcorssorcihev in forum VX Troubleshooting...
    Last Post: 01/21/2011, 06:20 AM
  5. High Engine Idle!
    By TYGVR in forum VX Talk...
    Last Post: 06/17/2003, 11:37 AM
