Results 1 to 15 of 23
Thread: Can Some one Help please!! Isuzu Bull
    I called Isuzu today to ask about a new gear selector input shaft seal. They tell me i cannot replace the seal by itself i need to purchase the hole gear selector assemble and that they no longer will make this part! So now i have a bleeding trans, from that seal and a perfect VX, but cant fix the bleeding! What to do? I really hate to give this vehicle up over a simple seal leak there has gotta be something that can be done? So i hope this is were you guys could come in? antone with this problem and or do you know of anyone that you may direct me to?
    Have you tried Merlin at St. Charles Isuzu? His contact info is on this site. If he can't get it for you it IS NOT available! Is is pretty much the parts guru around here.
    Awsome thanks!! ill give him a shout.
    1999, Ebony Black, VX ,1976
    I believe the trans is a 4L30E used in GM vehicles You may have better luck getting it from them. shawn
    1COOLVX
    Quote Originally Posted by psychos2 View Post
    Sweet!! I was gonna actually just buy a trans and part it, but if that is the case im all over itThanks for the tip ill let you know how i make out, Thanks Shawn
    Shift shaft seal
    This may be just a dumb question but.......I had my "shift shaft seal" replaced right after I got mine in December as it was leaking. Is that the same part you're talking about? If so, the part number on my receipt is 8-08644-709-0.....$8.35, and $98 labor.
    I happen to have one of the remaining "authorized" Isuzu repair places near me, and who did the work....wonder if that has anything to do with it?
    Just thought I'd mention this in case it's the same thing as yours.
    Jul 2008
    1999, Astral Silver, VX, 1508
    Here is a portion of my thread with the same problem back in 11/08. VX KAT is correct too above.
    Thread:
    Update for Trans. Fluid Leakage
    Finally got the car back in the shop with one of my Porsche Techs and we cleaned the area and took a peek. Cleaned the whole trans and found fluid leaking at the left side pan area and spreading. The only other seal in that area is above the pan gasket called the selector shaft seal. We pulled the mode switch housing off and low and behold found a very aged and brittle seal. We cleaned the old seal out, which fell apart upon contact, cleaned area, inserted new selector shaft seal, remount mode switch, top up fluid and run it. No leaks. 2nd day now and still no leaks. Selector shaft seal part #8-08644-709-0 and less than 6 bucks! What a relief and no more pink fluid all over the garage catch pan!
    Larry S.
    99 Astral Silver VX (176k)
    91 Porsche 928 S4 (73k)
    automatic trans your talking about rite( i dont know if they make a manual?) well if so yea i called my local and they said they couldnt help? were did you get it from?
    Yeah, automatic tranny. I got mine at Tim's Toyota in Prescott AZ (they're the authorized Isuzu place and they used to have a dealership).
    1-800-339-8467....and ask for "Isuzu parts".
    I ordered at parts window, they called when it was in.
    If you need me to order it, pick it up and mail it to you just shout. No prob at all, I've got the time and it's really close by.
    Jul 2008
    I got mine from my local Isuzu dealer in Escondido about 1 mile away.
    Classic VW/Isuzu
    888-671-8907 or 760-745-7551
    or
    Merlin back east
    just give them the part number VX KAT and I supplied and they can check price and availability
    Thanks Guys thats awsome and i will consider your offer Ill let you know how i make out.
    2001,FOX FIRE RED MICA,0251
    I found this on advance auto parts site.
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Seal-National_3271471-P_931_R|GRP60017_385498658___
    2001, Ebony Black, 1153
    Wink
    Found a bunch of different info on the item here is some of the stuff I found:
    Amazon.com has a couple different options:
    http://www.amazon.com/BCA-National-9...tive&carId=001
    http://www.amazon.com/gp/part-finder...0741&carId=001
    RockAuto.com seems to think it is a "8792S" but I am not sure about that one:
    2001 ISUZU VEHICROSS 3.5L 3475cc V6 FI (X) [6VE1] : Transmission-Automatic : Shift Shaft Seal Price Core Total
    BCA/NATIONAL Part # 8792S {Oil Seal / Nitrile / Shaft Size=0.5" Housing Bore=0.751" Outer Diameter=0.756" Width=0.192"}
    GMC 4L30-E 4 Spd. Automatic Transmission $3.58 @ Rock Auto
    photo of item:
    http://info.rockauto.com/BCA/Detail2...ages/Seals.jpg
    Item listed at Amazon, but amazon says it does not fit the vx:
    http://www.amazon.com/National-Oil-S...7852132&sr=1-4
    http://www.amazon.com/TIMKEN-8792S-T...7852132&sr=1-2
    Anyways, hope that helps.
    Jun 2007
    2001, Proton
    avoid rock auto
    They spam search words and claim to have your part. They may have it but why risk it if you have another option.
    well guys i got it done I installed the seal myself and it turned out great!!!! Thanks for the help with the part #er & also just the over all help was awsome! Oh can anyone tell me where to find the thread on the on/off switch for the T.O.D system and does it work well if you have an idea?
  1. Pit Bull Tires for the VX?????
    By LittleBeast in forum Wheels and Tires
    Last Post: 01/03/2012, 10:26 PM
  2. Isuzu bulletin confirms oil use bull****
    Last Post: 06/04/2010, 01:05 PM
  3. I've never ridden a bull, However.......
    By crotchrocket in forum Chit-Chat ...
    Last Post: 04/26/2010, 03:50 PM
  4. Bull Bar/Bumper
    Last Post: 04/16/2008, 04:59 PM
  5. bull bar from westinautomotive.com
    By xiaoz in forum VX Modifications...
    Last Post: 12/01/2003, 05:03 AM
