Results 1 to 15 of 29
Thread: Nasty Noise Fron Tranny On Acceleration
    97 Jap Import, Black BEAST
    After some fairly rough terrain and some clay / mud etc im getting a nasty noise from the front end. Best describes as a cross between metal vibration and grinding. i've only noticed at slow speed, i.e off the line as under normal acceleration it doesnt do it. Its doing it in 2wd
    I got under it last night and visually the only thing i could see that was odd was the front drive shaft on the transpher case (from the transpher case towards the front of the car) it had no rubber gaitors (boots) over the universal joints. my first thought is that craps got in their?? Is it supposed to be covered up? it looks like it should?
    Half shafts and CV's look fine on the front end, theres a bit of tranny slack but nothing major.
    Could it be gearbox?
    sure its the trans? first things i would do is grease the driveshaft to push any crap that got in the joints out, then i would check the front brakes for any kind of rocks or debris caught between the rotor and dust shield, if you got deep enough its possible something could have gotten into your differential too?
    Also if you are running Trooper skid plates, sometimes they bend and make contact with the front of the front driveshaft upon acceleration.
    had a good look around it this evening. cant see anything apart from one of the boots on the front propshaft has lost its retaining band, however its damn tight on there.
    The hole front end seems quit 'clunky' and theres a few clunks from the front Diff when rotating the slack in the front propshaft back and forth.
    I also got rid of a load of solid clay that was stuck above the diff etc.
    very anoying as its not something obviouse!!!!!
    anyone??
    more messing around today, its a definate grinding noise on acceleration that gets alot worse when the front wheels are engaged. In 2wd its only realy noticable at low speed.
    I was remembering also that a few weeks back i was getting some 'snatching' on the front end with a jolt and aclonk in the transmision, its a similar place the noise is coming from.
    Could the drive shaft CV joints be knackered or the front diff ?
    Need to disconnect the front end to see if it still makes the noise but locking hubs aren't cheap
    Come on peeps any ideas!! ??
    there's variouse noises from the front over speed bumps and i think it gets worse when turning so i recon its the CV joints.
    Got some free wheel hubs so will fit them, disengage the front drive train and see if the noise persists.
    James, jack the front up and spin the wheels, whilst laying under it (Use good axle stands!!!). It will allow you to locate the noise.
    There are many options... On my Pajero there is another bearing where the drive shaft goes through the knuckle (I think its called a needle bearing). That disintegrated on mine and gava very similar noise to the one you describe. I'll have a look in the manual and see if there is something similar.
    Cheers
    Nick
    Yes, It's the same as the Pajero. Have a look at the attached - item 6 is the one that had gone on my paj that caused the racket you describe...
    Nick
    Quote Originally Posted by alterastro View Post
    Nick
    Your a star!! thanks alot nick! Plus thos would only be ?16 each ! http://www.milneroffroad.com/img/productImages/9300.jpg
    Thanks mate. Got to go to claire's mums for the weekend
    so i'll fit the hubs and play with the wheels on monday night.
    Does she live in a castle too?...
    lol, nah shes in a normal house in Nottingham
    i've put the manual wheel hubs on and disconnected the front end transmission and ****!!!! its still making the same griding noise No idea what it is.
    There's noises all over the place from slack in the drive train and i can't pinpoint one that might be causing this noise under power. It's got to be either the transpher case, gear box or rear propshaft i suppose ??
    How about checking the front wheel bearings...
    Forgive me if this was already mentioned, but with all the muddin' you do, it's a distinct possibility.
    James, even with the manual hubs on the drive shafts may well still be turning. Have you jacked the front up and laid under it whilst someone spins a wheel?
    Nick
  1. Nasty old plugs!
    By ahdoman in forum VX Talk...
    Last Post: 10/04/2014, 07:54 PM
  2. Big satellite full of nasty stuff, coming' down
    Last Post: 01/29/2008, 09:19 AM
  3. outline of tranny filter on tranny pan......
    Last Post: 05/16/2006, 08:44 PM
  4. Help... Switching from mechanical tranny to fluid tranny???
    By ScubaSteve in forum VX Troubleshooting...
    Last Post: 10/03/2003, 03:41 AM
  5. need anything fron Japan?
    Last Post: 10/26/2002, 05:36 AM
