Results 1 to 6 of 6
Thread: Truck died while driving.
    Feb 2005
    01 Kaiser Silver
    OK so back from houston and yes I realize my last post was put in wrong area lol. OK So I am driving down to Houston with a steady 75 mph. I have been driving for about 3 hours straight when all of a sudden my truck starts to slow rapidly. I Push on gas and see rpms rise slowly but not enough to go (almost seemed like I ran outta gas). I pulled over and all lights came on (just like when you turn the ignition.) So I put truck in park turn truck off wait a moment and turn back on (yes I know now was wrong thing to do but too late now.) I turn truck back on and its running smoothly. I check for any codes that were thrown and all is clear. I continue down road maybe 3 more miles or so to my exit and pull into a gas station and fill up with gas since I was almost empty (gas gauge dances so not always sure.) I check dip stick and its dry, empty, notta . So I go inside to buy a qt of regular oil to mix with my synthetic because they didnt have any. Filled up with gas 17 gallons (always give it one click). When I got to friends house which was couple minutes I checked dipstick again and it was on full still (maybe engine didnt heat it up enough.) So in the morning check oil again codes all that good stuff and leave for the space center which is about 50 miles away. I arrive and check oil and its still full. Drive another 60 miles to another friends house and full.
    Now my question is and it has me scratching my head can a qt of oil (when engine is warm)make stick go from empty to full? Also I didnt run out of gas as I only filled up 17 gallons. Now I have driven all the way home some 4 hours straight and didnt have a problem or glitch. Now I will say this and dont shoot me. My inners are tore to shreads. I didnt grease them till I left Houston. I know priorities but if Ascinder can do it.. . Now I hadnt greased them in awhile but dont think that could have been culprit. Also I have never burned oil since I bought "it" at 69k miles. I had only traveled at that point 1k miles since I changed oil myself. Oh and I have 120k on the odo if that matters.
    Sorry for the long read but it freaked me out just thought I would get any opinions. As always thanks for the help
    1999, Ebony Black, VX ,1976
    I had mine quit like that 3 years ago and have not had it happen again since. and no it will not change the oil level by a qt. Do you pull the dipstick out and wipe it before actually checking the oil level ? When was the last time you checked your pcv valve? shawn
    1COOLVX
    Sep 2008
    1999 White IronMan
    wire harness over behind washer fluid resevior... take resevior off and reroute that harness over the top /side of resevior... similar things happened to me ... although if it's the wire harness.. it could be anywhere... I just found the problem to be that area...
    I had the power loss. like it turns off, once in a while... I mostly had all lights and radio flick off for 1-3 seconds then back on when I hit bumps.
    We sit together, my VX and I, until only the VX remains.
    --Iamironman
    Feb 2005
    01 Kaiser Silver
    Yup I whipe it down like a baby's bum lol..
    I didnt hit any bumps was all highway and nothing flickered but will check that in AM as well.
    had that happen to me on the highway once.. about 60mph.. replacing the fuel filter seemed to do the trick for me
    Mine did this once at a stop light. I had just been thru carwash tho so I assumed it was associated.
    Had you driven thru any rain? Coulda had some water accumulate under the coils.
    "Now I will say this and dont shoot me. My inners are tore to shreads. I didnt grease them till I left Houston."
    Bad Dumke. Bad VX owner. Hang your head in shame.
    I was 200 miles from home when my boots tore. My CVs were toast by the time I got home. Have you started getting a clicking noise when slowing down at low speeds?
  1. Transmission DIED!!
    By UWVX89 in forum VX Troubleshooting...
    Last Post: 11/19/2013, 07:04 AM
  2. VX died Help....
    By bcbike in forum VX Troubleshooting...
    Last Post: 12/03/2012, 06:32 PM
  3. my engine died
    Last Post: 03/30/2011, 07:11 AM
  4. Engine just died! Help please!
    By ShadowRider in forum VX Troubleshooting...
    Last Post: 05/08/2008, 03:06 PM
  5. VDU has died.
    By BigDave in forum VX Troubleshooting...
    Last Post: 04/17/2007, 07:16 PM
