Results 1 to 15 of 17
Thread: Blower speeds. Any advice
    Aug 2005
    1999, silver, 0887
    Post Blower speeds. Any advice
    My wife's '99 blower fan is only operating on high, the other three speeds are dead, and the fuse is good. I think it's the fan resistor that needs replacing? Any ideas out there? Many thanks.
    '99 Blk 0089
    Yes it's the resistor. Do a search and you'll find plenty of how-to's
    Here's a thread you need to read (& there's a hyperlink to another in there).
    http://www.vehicross.info/forums/sho...lower+resistor
    Aug 2005
    1999, silver, 0887
    Thanks for the guidance, I'll get a new resisitor.
    After you get the new one, you should try to fix the old one (just to keep it as a spare). It sounds fairly simple.
    blacksambo, you've received only partial info on this issue. Before you get a new resistor make sure you do some other things...
    There are two fuses to check, sounds like you checked at least one, just make sure you check the other if you haven't.
    Also, think about what caused the resistor to give out. Before you order one, get into the dash and blower housing to check things out.
    Resoldering the unit is very easy and it's free.
    When the blower quit working on my '99, I checked the fuses (one bad), checked the motor itself (good), resoldered the (bad) resistor, put things back together... and nothing... Took the resistor back out and it was fine so I checked the fuses again and the same one under the hood had blown again. The culprit ended up being the HVAC control panel... grease is used to keep the levers moving freely, in time these accumulate quite a bit of dust and what-not. I simply moved the switch back and forth quickly several times and sure enough, I haven't had a problem since! So the faulty switch caused the fuse to blow consistently and the resistor to fail once... apparently.
    This is the thread I used to find my way: http://www.vehicross.info/forums/sho...lower+resistor
    Jun 2007
    2001, Proton
    what
    Quote Originally Posted by blacksambo View Post
    Y/M/M is your wife?
    May 2002
    2000, Proton Yellow, VX, 0584
    Y/M/M is your wife?
    Scott / moncha.com
    Aug 2005
    1999, silver, 0887
    New resistor is in place works fine. Thanks for the repair offer but needed it done quick. (By the way, the resistors say do not repair on them. Maybe they know something we don't know?)
    "(By the way, the resistors say do not repair on them. Maybe they know something we don't know?)"
    Yup ... they make more money selling you a new one rather than telling you to fix your old one.
    Nov 2007
    1997 SILVER
    I might be talking through my arfes here, but I think the repair is to re-solder contacts that have separated.
    Being a resistor, they create heat, and the original unit could be assembled with a special solder that gives a thermal overload protection.
    This is achieved by using a special alloy solder that melts at a known temperature.
    If you do the repair with standard solder, you loose the thermal overload protection.
    We use this method to provide automatic closing of fire dampers in ships.
    It is called a "thermal fuse" or "fusable link".
    of course, I might be totally wrong in this case.
    Perhaps Deermagnet, or one of the electronic gurus will speak up.
    PK
    I seriously doubt that anyone is going to get a better solder joint using a radio shack iron than was achieved at the factory (even using a different alloy than was originally intended). The repaired solder joint will fail quicker than the original did.
    I've even soldered fusable links before & had them blow out again.
  1. rpm at highway speeds
    By mindaugas in forum VX Talk...
    Last Post: 07/21/2011, 01:38 PM
  2. A/C blower fan
    Last Post: 05/08/2009, 10:10 AM
  3. Blower motor going out
    By kelledee in forum VX Troubleshooting...
    Last Post: 11/07/2007, 08:16 AM
  4. blower switch
    Last Post: 09/26/2007, 09:33 AM
  5. GRINDING AT CERTIN SPEEDS hellllpppp!!!!!
    By 4x4boy in forum VX Troubleshooting...
    Last Post: 02/22/2007, 07:57 AM
