Results 1 to 3 of 3
Thread: transmission problem or need rebuild
    Oct 2003
    1999 white
    I need advice ASAP....yesterday I car just died when I driving (I try to move D 2 3 L and no response and engine running good ) last year my car had 1st and 2rd gear slips and fall back ...I took and advice to change the transmission and change the neutral safety switch ...running a year ...this time did I need to rebuild transmission or buy the neutral safety switch.
    What kind a thing I need to know before the job start ...The shop need $2195 for the transmission with 2 yr warranty is this a good price ??
    Thanked: 7
    Post
    Question: Do you notice that at start-up when you shift from park to drive (and back) if the dashboard gear indicator lights flicker and jump? That is one indication that you need a new mode switch. Also I am wondering if the shift panel connections are calibrated correctly.
    An electrical problem perhaps? Others can pipe in with ideas to help.
    Anita
    2000 Ebony #263
    AnitaProtich.com
    Oct 2003
    1999 white
    Question
    Thanks Anita : the indicator lights can jump around ...but when I move to D 2 3 L or R the car are not moving ..last year the gear are slips .I went to AAMCO the guy told me the oil are burn then I change the oil and the neutral safety switch.
    Before my car go down I hear the sound (like shhhhh and the 4 wheel light go up and down after 5 more min I hear othe sound(Shhhhhh and I pull over my car the the side and gear back to Park ....After that all gear are not working... any ideas what wong???
  1. Replies: 61
    Last Post: 03/02/2016, 10:31 AM
  2. Transmission went out:( Replace or Rebuild??
    By Ruflyf in forum VX Troubleshooting...
    Last Post: 01/07/2014, 10:51 AM
  3. need help and advice Transmission rebuild
    By DLNTHO in forum VX Troubleshooting...
    Last Post: 07/30/2010, 04:51 PM
  4. Transmission rebuild?
    Last Post: 02/01/2004, 09:10 AM
  5. Transmission Problem 2
    By Freon VX in forum VX Troubleshooting...
    Last Post: 09/27/2003, 09:54 PM
