Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 10 bolt lockers available again
  1. #16
    doulble check part numbers... but im almost positive 97 trooper CV's will fit the VX... as a matter of fact, almost anything suspension related will match the 97 trooper (according to indy4x)
    01, LineX tan/black, 1055
    Thanks jack, may be time to hit up the local U pull, see if I can score a set of old CVs, that would be good insurance if I go locked in the front.
    yup... like i said...give indy4x a call and make sure, but i talked to them for a while on the phone the other day, (before making my rather large order from them) and they seem to be pretty confident that if i order parts for a 97 trooper they will fit on my VX
  4. #19
    Whatja order....huh.....tell us....please.....bushings? HD tie rods....living vicariously through others.....bumper, killing me......getting made fun of....I should just end it all........NOT!!!!!!!!!!!!!!!!!!!
  5. #20
    Oct 2004
    99 Astral VX 1032
    With a front locker manual hubs are a must with our vehicle, otherwise your front end will be bound up and you WILL break something . Also you get them so they breakbefore your CVs do, that way you don't have to keep changing CVs which takes a while and not easily done on the trail, versus hubs which are right in front of you an a lot easier to get to.
    Ryan Christiansen
    Trooper Skid Plates, OME 912's, Stric9 Sliders, Load Warrior with extension, Apline sub in rear door, Apline front speakers, Alpine head unit, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Manual Hubs.http://picasaweb.google.com/RyanVehiX
  6. #21
    hmmm.... should i tell or not?? hmm.....
    well, i guess i got more info from them than anything else...
    - new calipers and pads all the way around
    - brake caliper paint (ordering soon)
    - inner and outer bearings on front, bearing for rear
    - braided brake lines
    - will be ordering new shocks soon
    - still deciding on-> HD tie rods, new CV's, and diff drop
    still finishing up all my fluid changes (havent had time..and every time i have time i forget a tool i need from work.. been making me very )
    done with the front and rear axles and x-case... still scared and dreading the transmission... and im probably gonna try to get the motor oil done while im at it
  7. #22
    Oct 2004
    99 Astral VX 1032
    My review of the lockers installed
    http://www.vehicross.info/forums/showthread.php?t=16232
  1. Aussie Lockers Insalled
    By VX1032 in forum VX Modifications...
    Last Post: 08/09/2009, 11:51 PM
  2. 12 bolt lockers are now available
    By Ldub in forum VX Talk...
    Last Post: 01/03/2009, 03:12 PM
  3. Front and Rear Aussie Lockers now available for the VX
    Last Post: 05/31/2007, 01:51 PM
  4. Woo Hoo, just got my lockers
    By Ascinder in forum VX Modifications...
    Last Post: 05/30/2007, 11:51 AM
  5. WMS - WMS VX 12 bolt?
    Last Post: 01/31/2006, 06:12 PM
