Page 2 of 2 FirstFirst 1 2
Results 16 to 17 of 17
Thread: grinding noise from front right wheel
  1. #16
    are you sure it is coming from right front wheel? I mean has anyone been outside the vehicle when your braking or does it just sound like that to you inside the vehicle? I ask because last summer same thing happened to me, and I was SURE it was coming from right front wheel, and it was a rear rotor, replaced both rear rotors and brakes and was fine, also I would use e brake instead of brake pedal to avoid the horrible noise and it did not make the noise with e brake.
  2. #17
    Mar 2006
    2001 FOXFIRE 0579
    Hey mannn, did you check the air in your tire?? tommy chong
    just for future referance, when a tire, or tires get low on air, the T O D will make a type of weird grinding noise also. not just on one wheel, but mor of a general grinding/winding down noise.
  1. Front end grinding
    By RabidPony in forum VX Troubleshooting...
    Last Post: 05/28/2013, 03:27 PM
  2. Replies: 5
    Last Post: 05/10/2011, 03:56 PM
  3. Calmini lift w/ grinding noise problem
    By drover65 in forum VX Modifications...
    Last Post: 08/03/2010, 05:23 PM
  4. Front end grabbing/ grinding?
    By Jay-Fazed in forum VX Troubleshooting...
    Last Post: 08/19/2009, 03:53 AM
  5. Driveline Grinding Noise at 60
    By VR4-Quest in forum VX Troubleshooting...
    Last Post: 06/30/2006, 09:09 PM
