Results 1 to 15 of 17
Thread: Repainting windshield wipers (not the blades)
    1999, Ebony Black, VX, 1614
    Question Repainting windshield wipers (not the blades)
    I did a quick search and came up with nothing, so I may be posting the question again.
    I want to repaint the wiper arms that have a few rust spots on them. Aside from the "how to" sand, paint, etc......How do I safely remove the wiper arms from the teeth/motor assembly so that they can be safely sanded and painted?
    I was just looking at mine the other day and considered doing the same thing you are planning. Keep us posted.
    Thanks
    Scott
    Quote Originally Posted by ScottinMA View Post
    Thanks
    will do....I figure my safe backup plan is to remove the blades....lay down a bunch of paper and tape to protect everything else and give them a quick shot of black spray. Perhaps in the garage where the air is still.
    Jun 2007
    2001, Proton
    i beleive
    you just have to remove the rubber grommet at the base of the unit and there is a bolt under there simply unbolt and the wiper arms should slip right off. I have been wanting to do this but have not done it yet so let us know if this is all that is needed.
    Sep 2008
    2000,Kaiser silver,VX,0576
    I also need to do the same thing. Mine aren't rusted but are discolored and faded. I do remember doing this on cars in the past and I know you have to really have them clean or the paint will "cats eye"(bubble up).
    IIRC, Its very simple, there is a cap that you pop off and then a nut you unscrew and they lift right off.
    Aug 2008
    Yes, Bart is exactly right. There is a protective cap at the base that "pivots up" exposing the retainer nut to remove the entire arm assembly.
    The key thing to do beforehand is to take a felt-tip Magic Marker Pen and make a mark on the head of the mounting pin (male end) and edge of hole on wiper arm (female end) so that it's easy re-mount the wiper arms perfectly back in the original position(s).
    In addition, you can also take a piece of masking tape and tape along the edge of the rubber blade wear it touches the glass windshield before removal. In this way, when the arms are re-attached then you'll know that they are re-installed in perfect original alignment.
    Sep 2008
    That's what I was trying to remember, to get it back right. Thanks Riff.
    Nov 2008
    1999 Astral Silver Vehicross #0525
    After reading and now know how to take the blade arms off I'm going to powder coat them this afternoon and I'll post some before and after pics thanks for the tips guys
    Wrench
    I did this about a month ago, & found that they don't exactly slip right off after being on for ten years...
    I pressed a 2 jaw puller into service, that was designed for tie rods/pulleys etc.(read: too big)
    Since then, I picked up a smaller 2 jaw puller from O'Reilleys for around $10.-.
    It'll fit way better next time.
    Mine weren't rusty, but I scuffed em' up real good with a scotchbrite pad, then cleaned them with 90% rubbing alcohol.
    A coulpe coats of primer, & a few coats of satin black...BAM, look new!...
    http://vehicross.info/forums/showpos...&postcount=185
    I did this too years ago on my other VX but I used the hammered grey, looks better than flat black.....need to do the current VX too.....awww another project!
    Jun 2005
    01 Dragon Green VX 1286
    I painted mine about 2 years ago.. I just taped the wipers off and painted them on the vehicle.
    When you tape off.. you use masking tape and news paper and cover the car within about 3 feet of the blade.. on all sides.. and do not use the mil-spec rule.. the bigger the glob the better the job
    good luck
    p.s. I couldn't get my arms off the vx either so figured this wasn't an impossible way to go
    Jun 2006
    1999, Black, Vehicross 0512
    I did mine about two years ago and they came right off without any difficulty. I went with a matte black after a light sanding and they still look good.
    Jul 2008
    1999, Astral Silver, VX, 1508
    I painted mine last year with a Rust-Oleum Professional flat black paint. I prepped them with a Scotch Brite Pad (Very Fine-Type A red pad) and they look great!!
    Larry S.
    99 Astral Silver VX (176k)
    91 Porsche 928 S4 (73k)
    Update
    2 weekends ago, I did this.
    Couldnt be easier.
    step 1: put a piece of masking tape above the blade to mark the current position of the blade.
    step 2: Remove rubber covers via flat head screw driver shimmy.
    step 3: Remove bolts
    --drivers side is easiest to remove with the hood open
    --passenger side is easiest to remove with the hood closed
    step 4:remove wipers
    --push down on the spring joint while lifting up
    step 5: remove blades
    step 6:sand down wipers
    step 7: spray paint with rustoleum flat black
    --let dry
    step 8: reverse steps 4, 3, 2, 1
    NOTE: the drivers side wiper is shorter than the passenger side.
    Results were superb.
  1. Replies: 1
    Last Post: 04/14/2007, 09:11 AM
  2. Windshield Wipers
    Last Post: 06/26/2006, 07:00 AM
  3. What about intermittent windshield wipers?
    By ScottinMA in forum VX Modifications...
    Last Post: 03/09/2005, 12:11 PM
  4. Repainting?
    By Denee in forum VX Talk...
    Last Post: 07/19/2004, 07:43 AM
  5. rotor blades
    Last Post: 11/03/2003, 05:03 AM
