What is everyone using to remove the front spindle nut that holds in the wheel bearings?
I have a Dana 44 tool that I think I can modify to make work.
John C.
John C.
Nothing special is needed. After removing the 3 screws, remove the plate and the nut will usually spin off by hand or using standard needlenose pliers. A screwdriver could be used to move it if stuck but the ones I have done did not require anything.
