Results 1 to 15 of 18
Thread: Abs tone ring
    Oct 2005
    '01 ebony VX 1427
    Abs tone ring
    I just put new R1 rotors, ceramic pads, and ss brake lines on yesterday and found the abs tone ring was cracked through on the pass front, my abs light has been on for a while is this the likely cause for the light?
    Past Owner
    erland,
    I was doing the same 3 mods last week and came across the same problem. I am still waiting on the ring parts. I was told by my mechanic that it would certainly cause the abs light to stay on.
    could someone post a picture of what this looks like......
    Gear
    You'll see it at about pic 9 - 10 down from the top here...
    http://www.vehicross.info/forums/showthread.php?t=11324
    Oct 2005
    '01 ebony VX 1427
    ok I have the new tone ring installed seemed to not fit properly, made a little noise when first starting to go but quits when gets up to speed. How can I get the abs light to go off?
    Gear
    Quote Originally Posted by erland View Post
    IMO, it shouldn't be making any noise at all, there is most likely a fitment issue. (sounds like wrong part from your description)
    I just installed my old tone rings on new rotors, there is no noise at any speed.
    Oct 2005
    '01 ebony VX 1427
    Called R1 concepts, they are sending me a new rotor, the bolt holes are misaligned.
    1997 Silver JDM 0623
    Hi whats a tone ring ?
    in the uk we have 'exciter rings' are we talking the same ?
    bolted to the brake disc with three bolts
    any trooper or rodeo with abs will have the same ring
    regards
    Steve
    Isuzu Vehicross 3.2 V6 24 Valve
    Gear
    Quote Originally Posted by Greasemonkey View Post
    regards
    Steve
    Yep...tone ring, exciter ring, speed sensor ring...they all have a nice "ring" to em'......
    I'd be interested to know what was making contact to cause the noise, I hope it wasn't the $peed $en$or...
    Past Owner
    I just did the same upgrades and had to replace one of the abs rings. The job is done and the brakes work fine, but the ABS light is staying on and the ABS pulse is not evident. No codes are detected and attempting to clear the codes does not reset the light. All of the sensors at the wheels are sending signals. Fuses are back in place and functional. I left the VX with the mechanic to fiddle with, but he is short of ideas that won't get into a lot more money. Could the ABS module be bad? Any ideas? Thanks.
    Oct 2005
    '01 ebony VX 1427
    I believe the new rotor holes were misaligned causing reing to not sit flush causing a slight bow so teeth do not line up with sensor properly.
    Past Owner
    erland,
    Were you able to get your ABS light to turn off?
    Oct 2005
    '01 ebony VX 1427
    I just installed the new rotor from r1 concepts (supplied at no charge!) tone ring dropped right in unlike with other rotor. I need to drive it to see if the light will go off. I would assume it needs to go a certain # of miles before it would decide to reset. If it does not go off I will have to take it in for diagnosis.
    hey just a quick 2 cents...... disconnect your negative battery terminal for about 15 minutes, it will reset your computer and help your ABS light come off
  1. Changing Front Rotors and Tone Ring
    By mcaramb in forum VX Troubleshooting...
    Last Post: 07/16/2014, 07:03 PM
  2. abs ring bolt stripped
    By djvx in forum VX Talk...
    Last Post: 05/09/2011, 10:00 PM
  3. HELP I need a ABS tone ring?
    By RAZ in forum VX Talk...
    Last Post: 08/29/2010, 01:25 PM
  4. ABS ring behind front rotor
    By Bob in forum VX Talk...
    Last Post: 04/21/2009, 10:13 AM
  5. does oil filler cap have rubber o-ring?
    By iownvx in forum VX Troubleshooting...
    Last Post: 10/28/2005, 11:20 AM
